Singularity
Dec 28, 2013Tutor
ReadyNAS Pro 6 - Best Expansion Path
My ReadyNAS Pro 6 is currently configured as follows Bay 1: 1Tb (931 allocated) Bay 2: 1Tb (931 allocated) Bay 3: 1Tb (931 allocated) Bay 4: 1Tb (931 allocated) Bay 5: 2Tb (1863 allocated) Bay...
mdgm-ntgr
Dec 28, 2013NETGEAR Employee Retired
With 6x4TB using dual-redundancy your volume capacity would be <16TB.
However using single-redundancy you could have a volume larger than 16TB provided you do a factory default with the disks in place.
