Singularity
Dec 28, 2013Tutor
ReadyNAS Pro 6 - Best Expansion Path
My ReadyNAS Pro 6 is currently configured as follows Bay 1: 1Tb (931 allocated) Bay 2: 1Tb (931 allocated) Bay 3: 1Tb (931 allocated) Bay 4: 1Tb (931 allocated) Bay 5: 2Tb (1863 allocated) Bay...
Dec 28, 2013Guru - Experienced User
To clarify: You cannot EXPAND a volume that is less than 16 TiB to a size >16 TiB. However, you can CREATE a volume that is bigger than 16 TiB by doing the factory default with all disks in place.
