Singularity
Dec 28, 2013Tutor
ReadyNAS Pro 6 - Best Expansion Path
My ReadyNAS Pro 6 is currently configured as follows Bay 1: 1Tb (931 allocated) Bay 2: 1Tb (931 allocated) Bay 3: 1Tb (931 allocated) Bay 4: 1Tb (931 allocated) Bay 5: 2Tb (1863 allocated) Bay...
mdgm-ntgr
Mar 02, 2014NETGEAR Employee Retired
I don't think it's in the manual. The manuals have been updated over time and are available at support.netgear.com
It is mentioned in a number of Release Notes.
Some expansion problems can't be foreseen or even if they are there may not be a possible workaround other than a factory reset. The original Pro was released back in 2008, years before the 16TB limit would become a problem.
