Singularity's avatar
Dec 28, 2013
ReadyNAS Pro 6 - Best Expansion Path
My ReadyNAS Pro 6 is currently configured as follows
Bay 1: 1Tb (931 allocated)
Bay 2: 1Tb (931 allocated)
Bay 3: 1Tb (931 allocated)
Bay 4: 1Tb (931 allocated)
Bay 5: 2Tb (1863 allocated)
Bay 6: 2Tb (1863 allocated)
I'm running RAIDiator 4.2.25 with RAID Level X-RAID2, 6 disks (with dual redundancy)
which gives a total usable space of 3683GB
I'm getting increasing errors on Disc 1 and it's likely that it will need to be replaced in the very near future. To take advantage of the situation I would like to install a larger disc and eventually would like to increase the size of all my drives. If I upgrade disc 1 to 2TB it will not give me any extra storage. However if I replace the 2No 1TB discs in the first 2 bays with 2TB discs my storage will increase to 5483GB. However I would like to think long term and as the price difference between the 2TB and 3TB discs is relatively small I'm considering using 3TB discs throughout.
So if I start off by swapping my drives in bays 1 and 2 with 3TB drives what can I expect and is that the best procedure? I will eventually swap all the discs with 3TB discs and if so what is the best procedure to adopt. I've heard of the 8TB and 16TB limits but not exactly sure what they are. Also will I need to do a factory reset at some time and if so should that be with the Pro 6 fully loaded with 3TB discs or can it be done in a peace-meal fashion. I accept that I will need to backup my data or use alternative storage prior to doing a factory reset as it will wipe all my data etc.
  • I understand, but i bought it in 2012, and the 4TB disks where well discovered,
    I would have understood if i bought it in 2008, but i didnt.
    Now im working with the dealer for a solution, hopefully a 516 or similiar can solve this.
ProSupport for Business
