steveoelliott
Sep 21, 2015Luminary
Readynas Pro 6 - Pro Support
Hi all, I am looking to find out more details regarding pro support for my Readynas Pro 6. However, when I called into support they advised that only per incident support is available. The reason I a...
- Sep 22, 2015
It is what it is.
The 314 is a suitable replacement for the Pro 4. It has a faster CPU than the Pro 4 and double the RAM. It is not as powerful as the Pro 6 however. It depends on the use case whether it would be appropriate.The 516 has a more powerful CPU than the Pro 6 and 4x the RAM.
Yes you can run dual-redundancy on the 314. On a 4-bay system with dual-redundancy the capacity of the smallest disk would be used.On rackmount the 3130 or for a 12-bay the 3220/4220 depending on budget would be the way to go.
steveoelliott
Sep 22, 2015Luminary
Thanks for the feedback... It is somewhat disapointing that pro support is not offered on the older units and one of them isn't even 3 years old yet! I didn't go for an OS6 system back then since they were very much in their infancy.
So how reliable are the new 516 and other OS6 based models compared with models like the pro 6?
From a performance and reliability perspective (we don't need 6 drives) would the 314 be a good match for the pro 6 that ultimately we will be looking to replace? I presume the 314 can run dual redunancy with X-RAID2.
Finally, if we were to go for a rack mount model, which one would be a close match?
mdgm-ntgr
Sep 22, 2015NETGEAR Employee Retired
It is what it is.
