Francescoli
Jul 30, 2026Tutor
ReadyNAS Pro 6 Business Edition RNDP6000 Booy Issue.
Apologies as I know this unit is not supported at all these days but has served me well so wanted to try and get this working again. OS 6 6.10.9 was installed (my initial OS 6 upgrade with the h...
- Aug 01, 2026
Your symptom sounds like you are trying to boot an OS6 recovery USB. For legacy units updated to OS6, you have to use an OS4.2.x style USB recovery key but re-name the OS6 image file as if it's an OS4.2.x one.
Jul 30, 2026Guru - Experienced User
Francescoli wrote:Any advice would be appreciated.
Not convinced a USB recovery was the right move.
Lots of possible causes here, including a failing PSU or a problem disk.
Have you tried booting normally with the monitor connected? Any clues there?
