Francescoli
Jul 30, 2026Tutor
ReadyNAS Pro 6 Business Edition RNDP6000 Booy Issue.
Apologies as I know this unit is not supported at all these days but has served me well so wanted to try and get this working again. OS 6 6.10.9 was installed (my initial OS 6 upgrade with the h...
- Aug 01, 2026
Your symptom sounds like you are trying to boot an OS6 recovery USB. For legacy units updated to OS6, you have to use an OS4.2.x style USB recovery key but re-name the OS6 image file as if it's an OS4.2.x one.
Francescoli
Jul 30, 2026Tutor
HI Stephen,
Yes boots and ReadyNAS gets stuck at 99% but once the initial load finishes output to the monitor clears. I was hoping it would have a Linux login or something but no luck. I've reinstalling OS via boot menu a few times but same symptoms.
- StephenBJul 30, 2026Guru - Experienced User
You could try tech support mode. If that boots normally you could try manually mounting the volume.
