Francescoli
Jul 30, 2026Tutor
ReadyNAS Pro 6 Business Edition RNDP6000 Booy Issue.
Apologies as I know this unit is not supported at all these days but has served me well so wanted to try and get this working again. OS 6 6.10.9 was installed (my initial OS 6 upgrade with the h...
- Aug 01, 2026
Your symptom sounds like you are trying to boot an OS6 recovery USB. For legacy units updated to OS6, you have to use an OS4.2.x style USB recovery key but re-name the OS6 image file as if it's an OS4.2.x one.
Francescoli
Jul 30, 2026Tutor
Thanks, I'll try that Stephan and let post the results. On bootup the system states no SMART errors but I'll see what results come from smartctl.
- StephenBJul 30, 2026Guru - Experienced User
The lockup at 99% suggests file system corruption. Hopefully either not the case, or minor.
Normally the smart stats only are updated if a disk i/o operation generates an error. The full smartctl test will read every sector on the disk, so that will uncover any latent problems.
