Francescoli
Jul 30, 2026Tutor
ReadyNAS Pro 6 Business Edition RNDP6000 Booy Issue.
Apologies as I know this unit is not supported at all these days but has served me well so wanted to try and get this working again. OS 6 6.10.9 was installed (my initial OS 6 upgrade with the h...
- Aug 01, 2026
Your symptom sounds like you are trying to boot an OS6 recovery USB. For legacy units updated to OS6, you have to use an OS4.2.x style USB recovery key but re-name the OS6 image file as if it's an OS4.2.x one.
Francescoli
Jul 30, 2026Tutor
Hi Stephen,
Here are the results:
Here are the disk attributes (x6)
=== START OF READ SMART DATA SECTION ===
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Aborted by host 10% 63886 -
# 2 Short offline Completed without error 00% 63886 -
# 3 Extended offline Completed without error 00% 63187 -
# 4 Extended offline Completed without error 00% 62532 -
# 5 Extended offline Completed without error 00% 61906 -
# 6 Extended offline Completed without error 00% 61079 -
# 7 Extended offline Completed without error 00% 60339 -
# 8 Extended offline Completed without error 00% 59667 -
# 9 Extended offline Completed without error 00% 58178 -
#10 Extended offline Aborted by host 80% 57449 -
#11 Extended offline Completed without error 00% 56964 -
#12 Extended offline Completed without error 00% 56366 -
#13 Extended offline Completed without error 00% 55831 -
#14 Extended offline Aborted by host 40% 55208 -
#15 Extended offline Completed without error 00% 53903 -
#16 Extended offline Completed without error 00% 53180 -
#17 Extended offline Completed without error 00% 52438 -
#18 Extended offline Completed without error 00% 51765 -
#19 Extended offline Completed without error 00% 51022 -
#20 Extended offline Completed without error 00% 50278 -
#21 Extended offline Completed without error 00% 49558 -
root@readynas:/# smartctl -l selftest /dev/sdb
smartctl 6.6 2017-11-05 r4594 [x86_64-linux-4.4.68.x86_64.1] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
# 1 Short offline Aborted by host 20% 63867 -
# 2 Short offline Completed without error 00% 63867 -
# 3 Extended offline Completed without error 00% 63168 -
# 4 Extended offline Completed without error 00% 62514 -
# 5 Extended offline Completed without error 00% 61888 -
# 6 Extended offline Completed without error 00% 61061 -
# 7 Extended offline Completed without error 00% 60320 -
# 8 Extended offline Completed without error 00% 59649 -
# 9 Extended offline Completed without error 00% 58159 -
#10 Extended offline Aborted by host 80% 57430 -
#11 Extended offline Completed without error 00% 56945 -
#12 Extended offline Completed without error 00% 56347 -
#13 Extended offline Completed without error 00% 55812 -
#14 Extended offline Aborted by host 40% 55190 -
#15 Extended offline Aborted by host 10% 54586 -
#16 Extended offline Completed without error 00% 53884 -
#17 Extended offline Completed without error 00% 53162 -
#18 Extended offline Completed without error 00% 52419 -
#19 Extended offline Completed without error 00% 51746 -
#20 Extended offline Completed without error 00% 51004 -
#21 Extended offline Completed without error 00% 50260 -
root@readynas:/# smartctl -l selftest /dev/sdc
# 4 Extended offline Completed without error 00% 62533 -
# 5 Extended offline Completed without error 00% 61907 -
# 6 Extended offline Completed without error 00% 61080 -
# 8 Extended offline Completed without error 00% 59668 -
# 9 Extended offline Completed without error 00% 58179 -
#14 Extended offline Aborted by host 40% 55209 -
#15 Extended offline Aborted by host 10% 54605 -
#16 Extended offline Completed without error 00% 53903 -
#17 Extended offline Completed without error 00% 53181 -
#18 Extended offline Completed without error 00% 52438 -
#19 Extended offline Completed without error 00% 51766 -
#20 Extended offline Completed without error 00% 51023 -
#21 Extended offline Completed without error 00% 50279 -
root@readynas:/# smartctl -l selftest /dev/sdd
# 1 Short offline Aborted by host 10% 63887 -
# 2 Short offline Completed without error 00% 63887 -
# 3 Extended offline Completed without error 00% 63188 -
# 6 Extended offline Completed without error 00% 61081 -
# 7 Extended offline Completed without error 00% 60340 -
#10 Extended offline Aborted by host 80% 57450 -
#12 Extended offline Completed without error 00% 56367 -
#13 Extended offline Completed without error 00% 55832 -
#15 Extended offline Aborted by host 10% 54606 -
#16 Extended offline Completed without error 00% 53904 -
#18 Extended offline Completed without error 00% 52439 -
root@readynas:/# smartctl -l selftest /dev/sde
# 1 Short offline Completed without error 00% 63887 -
# 2 Extended offline Completed without error 00% 63188 -
# 3 Extended offline Completed without error 00% 62533 -
# 4 Extended offline Completed without error 00% 61907 -
# 5 Extended offline Completed without error 00% 61081 -
# 6 Extended offline Completed without error 00% 60339 -
# 7 Extended offline Completed without error 00% 59668 -
# 8 Extended offline Completed without error 00% 58179 -
# 9 Extended offline Aborted by host 80% 57450 -
#10 Extended offline Completed without error 00% 56964 -
#11 Extended offline Completed without error 00% 56367 -
#12 Extended offline Completed without error 00% 55832 -
#13 Extended offline Aborted by host 40% 55209 -
#14 Extended offline Aborted by host 10% 54606 -
#15 Extended offline Completed without error 00% 53904 -
#16 Extended offline Completed without error 00% 53181 -
#17 Extended offline Completed without error 00% 52439 -
#18 Extended offline Completed without error 00% 51766 -
#19 Extended offline Completed without error 00% 51023 -
#20 Extended offline Completed without error 00% 50279 -
root@readynas:/# smartctl -l selftest /dev/sdf
# 5 Extended offline Completed without error 00% 61082 -
# 9 Extended offline Aborted by host 80% 57449 -
#12 Extended offline Completed without error 00% 55831 -
#14 Extended offline Aborted by host 10% 54605 -
- FrancescoliJul 31, 2026Tutor
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0
2 Throughput_Performance 0x0005 134 134 054 Pre-fail Offline - 105
3 Spin_Up_Time 0x0007 153 153 024 Pre-fail Always - 418 (Average 441)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 662
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 128 128 020 Pre-fail Offline - 18
9 Power_On_Hours 0x0012 091 091 000 Old_age Always - 63895
10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 256
22 Helium_Level 0x0023 100 100 025 Pre-fail Always - 100
192 Power-Off_Retract_Count 0x0032 098 098 000 Old_age Always - 3122
193 Load_Cycle_Count 0x0012 098 098 000 Old_age Always - 3122
194 Temperature_Celsius 0x0002 157 157 000 Old_age Always - 38 (Min/Max 18/55)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0
root@readynas:/# smartctl -A /dev/sdb
2 Throughput_Performance 0x0005 133 133 054 Pre-fail Offline - 108
3 Spin_Up_Time 0x0007 152 152 024 Pre-fail Always - 425 (Average 440)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 720
9 Power_On_Hours 0x0012 091 091 000 Old_age Always - 63876
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 257
192 Power-Off_Retract_Count 0x0032 096 096 000 Old_age Always - 5011
193 Load_Cycle_Count 0x0012 096 096 000 Old_age Always - 5011
194 Temperature_Celsius 0x0002 150 150 000 Old_age Always - 40 (Min/Max 18/58)
root@readynas:/# smartctl -A /dev/sdc
2 Throughput_Performance 0x0005 134 134 054 Pre-fail Offline - 103
3 Spin_Up_Time 0x0007 155 155 024 Pre-fail Always - 413 (Average 435)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 732
192 Power-Off_Retract_Count 0x0032 098 098 000 Old_age Always - 3149
193 Load_Cycle_Count 0x0012 098 098 000 Old_age Always - 3149
194 Temperature_Celsius 0x0002 153 153 000 Old_age Always - 39 (Min/Max 18/56)
root@readynas:/# smartctl -A /dev/sdd
2 Throughput_Performance 0x0005 132 132 054 Pre-fail Offline - 112
3 Spin_Up_Time 0x0007 151 151 024 Pre-fail Always - 442 (Average 428)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 754
9 Power_On_Hours 0x0012 091 091 000 Old_age Always - 63896
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 255
192 Power-Off_Retract_Count 0x0032 098 098 000 Old_age Always - 3160
193 Load_Cycle_Count 0x0012 098 098 000 Old_age Always - 3160
194 Temperature_Celsius 0x0002 162 162 000 Old_age Always - 37 (Min/Max 18/55)
root@readynas:/# smartctl -A /dev/sde
3 Spin_Up_Time 0x0007 154 154 024 Pre-fail Always - 419 (Average 437)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 751
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 258
192 Power-Off_Retract_Count 0x0032 097 097 000 Old_age Always - 3926
193 Load_Cycle_Count 0x0012 097 097 000 Old_age Always - 3926
root@readynas:/# smartctl -A /dev/sdf
2 Throughput_Performance 0x0005 134 134 054 Pre-fail Offline - 104
3 Spin_Up_Time 0x0007 157 157 024 Pre-fail Always - 416 (Average 422)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 743
192 Power-Off_Retract_Count 0x0032 098 098 000 Old_age Always - 3161
193 Load_Cycle_Count 0x0012 098 098 000 Old_age Always - 3161
194 Temperature_Celsius 0x0002 157 157 000 Old_age Always - 38 (Min/Max 19/54)
- StephenBAug 01, 2026Guru - Experienced User
Sorry about the lag - I've been pretty busy.
The disks look ok. But possibly the file system is damaged.
You could check for that with tech support mode, but it does require running several linux commands.
Do you have a backup? If you do, another path is to do a factory reset and restore the data. Time consuming, but ensures you have a completely clean file system.
- FrancescoliAug 01, 2026Tutor
Hi Stephen,
Sorry, I've only just seen your reply too. I'm happy to run any list of commands you suggest as it be good to see if we can fix this.
I had some backups from a few months ago and personal stuff is all backed up and ok and up-to-date. But have been working on some old synth libraries recently which were not backed up so, will be handy to have those back.
In the meantime, I thought I would look up how to connect external USB storage, mount and use that to transfer files over. That went ok-ish but large files were not copied due to me using fat32 (for compatibility).
So, I decided to try using a network backup alternative with NFS using rsync to my Synology. I have setup the Synology now with a "recovery" shared drive and finally managed to mount that successfully via ReadyNAS shell. I have an initial file copy running over the network ok and nothing has crashed so far touch wood!
If that finishes ok, I've got the rest of the commands ready to run from SecureCRT to copy the rest of the directories.
If it completes ok, I'll run the commands you suggest to see if that fixes things - as would be good to know. If it does and all is stable again, will try firmware upgrade to OS 6 6.10.10 with the 4.2 recovery usb built after Sandshark mentioned I was using the incorrect version if needs be.
Thanks again to you (and Sandshark) for your time and advice.
