Francescoli's avatar
Francescoli
ReadyNAS Pro 6 Business Edition RNDP6000 Booy Issue.
Apologies as I know this unit is not supported at all these days but has served me well so wanted to
try and get this working again.
OS 6 6.10.9 was installed (my initial OS 6 upgrade with the help of an excellent Tech support person a few years ago) and has updates and run flawlessly since.
I recently tried a snapshot restore to go to some older files and the system hung/crashed.
I couldn't access web Gui, so tried an OS reinstall and then all worked fine.
Disks were doing a resync and all finished ok.
Next morning the system was powered up but was powered up but hung with no PING or access at all.
I have rigged up a Monitor, Keyboard and mouse and created a USB recovery key created.
Thought I would try to update to ReadyNASOS-6.10.10-x86_64 via USB:
1. Insert USB in front USB port.
2. Rebooted with backup button pressed - BIOS loads and syslinux loads but just then monitor screen goes blank and the LCD screen stays on "ReadyNAS"
I've tried pressing the reset or pressing the backup button to see if the options scroll but not go.
Am I missing something here or should this boot into the USB?
I'd like to get working even just to access/backup the current shares if possible, so don't want to go the factory reset if possible.
Any advice would be appreciated.
Many thanks
  • Your symptom sounds like you are trying to boot an OS6 recovery USB.  For legacy units updated to OS6, you have to use an OS4.2.x style USB recovery key but re-name the OS6 image file as if it's an OS4.2.x one.
ProSupport for Business
