tony359
Mar 30, 2023Apprentice
ReadyNAS Pro 6 crashed again
Hello all, My ReadyNAS Pro6 periodically stops responding to the network. When that happens I can push the button to shutdown it but it will sit on "shutting down" forever and then I'll have to p...
tony359
Apr 01, 2023Apprentice
Thank you. So probably the RAM update was not necessary after all 🙂
The NAS disappeared from the network again yesterday (third time in a day). I went ahead and removed iDrive and also Plex (which was disabled).
This time, as the previous time, I was able to gracefully shut it down via front panel. I know we've been there before but I'm thinking whether I have a network issue. That would not explain the NAS hanging when shutdown via front panel though.
If it happens again I would like to do a software reinstall, can someone please remind me how it's done on OS6? If memory serves, that would just wipe the OS partition. What about all my settings (FTP, shares etc)?
I might also want to re-seat the PCBs which take the network signal from the motherboard to the network sockets just in case.
If that still doesn't work, I might have a HW failure - I guess I could start with using an external ATX PSU to make sure it's not that one.
A friend of mine has looked into the logs for me and advised that the Kernel used by this FW has a known bug when handling files - I'm trying to find out more details about that but I'm sure I don't need to tell Netgear about these things!
Sandshark
Apr 01, 2023Sensei
If you leave the SSH session open and running top, does it also freeze? If so, do the processes at the top of the list by CPU use offer any clues?
- tony359Apr 01, 2023Apprentice
I can answer this already as I had TOP running the last two crashes. Yes, SSH drops. I did not take a screenshot but I don't remember seeing any unusual things. The NAS has been running heavily for several hours now (doing some backups!) and I have an SSH window with a continuous ping.
However, the NAS doesn't normally crash when it's in use - at least it's never happened to me. I have my Blu Ray collection on it so the NAS regularly streams high bitrate content (as a file, not as a stream) and never had glitches.If it happens, it's when it's idle; then I try to access it and it's gone.
Looking at the OS reinstall, it looks like I might need the USB recovery rather than the OS reinstall if not mistaken? That wipes the OS partition if I understand correctly. What kind of settings should I expect to reset?
Thanks
- StephenBApr 01, 2023Guru - Experienced User
USB recovery rewrites the flash in the NAS. It doesn't directly affect the OS partition on the disks. Not indicated in your situation, as there is no evidence the flash has been corrupted.
OS reinstall does a partial reinstallation of the OS on the disks, but it does not rebuild the entire partition. It will
- change the admin password back to admin
- reset the IP config to DHCP with no bonding
- disable volume quota (which can be re-enabled from the volume settings wheel).
If you want to completely rebuild a new OS partition, you will need to do a factory default, and then reconfigure the NAS and restore all the data from backup.
Thanks Stephen,
I don't have an easy way to restore my NAS, it's 12TB of data which are more or less backed up somewhere but only for emergencies.
So none of the options perform a full OS reinstall.
Is there a documented manual mode to wipe the OS partition and reinstall?
Thanks for your help so far!
No, and it's not an avenue I've ever explored.
If you can live w/o the NAS for a while, you could try powering down and removing the disks. Then do a fresh install on one or more spares. Then put some of your data on, and see if the problem still occurs.
Thanks.
To be fair, I guess that removing the whole partition would also remove the configuration of the RAID, shares etc. Probably that's why it only comes with a full reset.
Yes, I was thinking the same thing, remove the drive, install a couple of spare drives and test.IF it keeps crashing on a daily basis, sure. But if it stops and it crashes every 2 months, that's more complicated.
Today, so far so good and it's been pretty active transferring stuff. Finger crossed.Mildly unrelated question, I see the OS is on Debian 8 which is the extended support version. How come it's still on 8.3 when the last version is 8.11? I know those things are never the latest but 8 is not the latest 🙂
Yes.
Netgear support can rebuild it, but I've never seen a procedure. Getting ReadyNAS support seems pretty impossible (and you wouldn't get it anyway on Pro-6 converted to OS-6).
Sad to hear about Netgear support - not that I am expecting support as you say.
I was checking out TrueNAS and I see they are on the latest FreeBSD version available. I understand why Netgear doesn't want to move things too fast, but it feels there is not much development going on - or is it just my impression?
- StephenBApr 02, 2023Guru - Experienced User
Netgear hasn't said, but many of us are thinking that they have been quiet-quitting the NAS business for some time. They haven't introduced a new ReadyNAS platform since 2017. And they removed ReadyNAS from the product list on the main website last summer.
- tony359Apr 02, 2023Apprentice
I see. Indeed all new NAS announcements I see around are QNAP or Synology.
Thanks, I'll bear that in mind. I'll start looking into options - software options even though the Pro6 is getting old so less and less people would feel the need to have an option.
Are we aware of anything available for it? TrueNAS and similar?
The good news is that my NAS is still online. I hope I don't have to get in touch with iDrive to report an issue with their plugin as they've never been too helpful. The plugin has recently received an upgrade to support OTP. But not so recently to explain the crashes, it was many weeks ago.
- SandsharkApr 02, 2023Sensei
You can find threads on the web about installing a more generic Linux based server on a ReadyNAS. The Pro6 has an internal VGA header, and the installation requires you get the proper cable to attach a monitor, but it's not too hard to find. That actually makes it a better platform than some newer ReadyNAS. Every solution I've seen changes the BIOS to boot directly from the drives instead of the boot PROM, but you ought to be able to build a small OS on the boot PROM that then chain-loads the one on the drives, just as ReadyNAS OS does. (But don't ask me how, I'm more of a hardware guy.). You should also be able to install Xpenology, though there are legality issues with it. I can see where using Xpenology would be beneficial if you are looking for a Synology as your new main NAS.
This thread: Ready-NAS-RN316-Xpenology-installed-with-success is by a user who successfully installed Xpenology on a 316 (which has a built-in HDMI port) and I've even seen posts on successfully installing it on a NAS without a display, like this one: https://xpenology.com/forum/topic/1343-how-to-install-xpenology-on-an-old-netgear-rndu-4000/.
For those with a Pro BE or Pro Pioneer that have not upgraded the processor and added RAM, I'd do that upgrade before trying to install any other OS on it.
Thanks.
Well the NAS crashed again so not sure what to do next now. I guess I could go with plan B, remove the drives and test with a couple spare drives to see if it disappears again.
I was aware of the VGA header, would it be worth connecting it to a monitor? Does it show a real time log or something? It might help in troubleshooting what is going on.
I've noticed that if I unplug the network when it's not reachable, the front panel informs me the network has changed so that tells me the kernel is not gone.
I guess I shall try an OS reinstall after all. It can't hurt, right?
Sigh, the NAS is pretty important on my workflow.
With ReadyNASOS installed, the only advantage of the VGA header is to see what's happening during boot, before you can start an SSH session, or to make BIOS setting changes. Once booted. it gives you nothing you don't get from SSH (unless, perhaps, SSH also crashes).
Yes, SSH crashes 🙂 (Well, the box disappears from the network so I cannot monitor anymore)
What do I get via VGA? a terminal or a live log page? Does that VGA adaptor have a name?
Can someone please confirm this is the correct way to enter the boot menu on my Pro6?
Thanks
I've now seen this happening on at least two crash events. nv6lcd is the LCD driver. Does any of this ring a bell?
Apr 02 15:58:40 Enterprise-NAS kernel: alloc_fd: slot 3 not NULL!
Apr 02 15:58:40 Enterprise-NAS kernel: alloc_fd: slot 4 not NULL!
Apr 02 15:58:40 Enterprise-NAS kernel: general protection fault: 0000 [#1] SMP
Apr 02 15:58:40 Enterprise-NAS kernel: Modules linked in: nv6lcd(O) vpd(PO)
Apr 02 15:58:40 Enterprise-NAS kernel: CPU: 1 PID: 24751 Comm: bash Tainted: P O 4.4.218.x86_64.1 #1
Apr 02 15:58:40 Enterprise-NAS kernel: Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./To be filled by O.E.M., BIOS 080014 07/26/2010
Apr 02 15:58:40 Enterprise-NAS kernel: task: ffff88013c380a80 ti: ffff88008debc000 task.ti: ffff88008debc000
Apr 02 15:58:40 Enterprise-NAS kernel: RIP: 0010:[<ffffffff88134ee0>] [<ffffffff88134ee0>] dup_fd+0x176/0x1e4
Apr 02 15:58:40 Enterprise-NAS kernel: RSP: 0018:ffff88008debfdc0 EFLAGS: 00010206
Apr 02 15:58:40 Enterprise-NAS kernel: RAX: 0000000000000001 RBX: ffff8800ab8b9080 RCX: ffff88009573c808
Apr 02 15:58:40 Enterprise-NAS kernel: RDX: 28e00215ea331f00 RSI: ffff88004b9645e8 RDI: ffff88009573c800
Apr 02 15:58:40 Enterprise-NAS kernel: RBP: ffff88008debfe00 R08: ffff88009ad4a400 R09: ffff88009ad4a400
Apr 02 15:58:40 Enterprise-NAS kernel: R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000100
Apr 02 15:58:40 Enterprise-NAS kernel: R13: ffff88008e9aa800 R14: 0000000000000100 R15: ffff8800ab8bb180
Apr 02 15:58:40 Enterprise-NAS kernel: FS: 00007f40de9dc700(0000) GS:ffff88014fc80000(0000) knlGS:0000000000000000
Apr 02 15:58:40 Enterprise-NAS kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Apr 02 15:58:40 Enterprise-NAS kernel: CR2: 00007ffdc7ac6f78 CR3: 000000004b8ac000 CR4: 0000000000000670
Apr 02 15:58:40 Enterprise-NAS kernel: Stack:
Apr 02 15:58:40 Enterprise-NAS kernel: ffff88009ad4a400 ffff8800ab8bb1a8 ffff88009ad4a400 0000000001200011
Apr 02 15:58:40 Enterprise-NAS kernel: 0000000000000000 ffff88013c380a80 00007f40de9dc9d0 ffff88013c386900
Apr 02 15:58:40 Enterprise-NAS kernel: ffff88008debfec8 ffffffff880625a2 ffffffff88094235 000000008debfe70
Apr 02 15:58:40 Enterprise-NAS kernel: Call Trace:
Apr 02 15:58:40 Enterprise-NAS kernel: [<ffffffff880625a2>] copy_process+0x5b1/0x1611
Apr 02 15:58:40 Enterprise-NAS kernel: [<ffffffff88094235>] ? vprintk_default+0x9/0xb
Apr 02 15:58:40 Enterprise-NAS kernel: [<ffffffff8811fc68>] ? get_empty_filp+0x141/0x185
Apr 02 15:58:40 Enterprise-NAS kernel: [<ffffffff881351e5>] ? __alloc_fd+0x137/0x167
Apr 02 15:58:40 Enterprise-NAS kernel: [<ffffffff88063744>] _do_fork+0x78/0x243
Apr 02 15:58:40 Enterprise-NAS kernel: [<ffffffff8806e9d8>] ? __set_current_blocked+0x3d/0x51
Apr 02 15:58:40 Enterprise-NAS kernel: [<ffffffff8806eb38>] ? sigprocmask+0x5b/0x5f
Apr 02 15:58:40 Enterprise-NAS kernel: [<ffffffff88063981>] SyS_clone+0x14/0x16
Apr 02 15:58:40 Enterprise-NAS kernel: [<ffffffff888e990a>] entry_SYSCALL_64_fastpath+0x1e/0x8e
Apr 02 15:58:40 Enterprise-NAS kernel: Code: 4d d0 e8 f5 fa ff ff 4c 8b 4d d0 4d 8b 6c 24 08 31 c0 45 89 f4 49 8b 79 08 48 89 f9 4c 39 e0 74 32 49 8b 54 c5 00 48 85 d2 74 07 <f0> 48 ff 42 38 eb 15 49 8b 71 18 48 0f b3 06 89 c6 4d 8b 59 20
Apr 02 15:58:40 Enterprise-NAS kernel: RIP [<ffffffff88134ee0>] dup_fd+0x176/0x1e4
Apr 02 15:58:40 Enterprise-NAS kernel: RSP <ffff88008debfdc0>
Apr 02 15:58:40 Enterprise-NAS kernel: ---[ end trace 918f7e9d8e3bfb6b ]---
Apr 02 15:58:41 Enterprise-NAS kernel: general protection fault: 0000 [#2] SMP
Apr 02 15:58:41 Enterprise-NAS kernel: Modules linked in: nv6lcd(O) vpd(PO)
Apr 02 15:58:41 Enterprise-NAS kernel: CPU: 1 PID: 24751 Comm: bash Tainted: P D O 4.4.218.x86_64.1 #1
Apr 02 15:58:41 Enterprise-NAS kernel: Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./To be filled by O.E.M., BIOS 080014 07/26/2010
Apr 02 15:58:41 Enterprise-NAS kernel: task: ffff88013c380a80 ti: ffff88008debc000 task.ti: ffff88008debc000
Apr 02 15:58:41 Enterprise-NAS kernel: RIP: 0010:[<ffffffff8811cabc>] [<ffffffff8811cabc>] filp_close+0x9/0x6f
Apr 02 15:58:41 Enterprise-NAS kernel: RSP: 0018:ffff88008debfba0 EFLAGS: 00010206
Apr 02 15:58:41 Enterprise-NAS kernel: RAX: 0000000000000001 RBX: ffff8800ab8b9080 RCX: ffff88008e9aa800
Apr 02 15:58:41 Enterprise-NAS kernel: RDX: 0000000080000000 RSI: ffff8800ab8b9080 RDI: 28e00215ea331f00
Apr 02 15:58:41 Enterprise-NAS kernel: RBP: ffff88008debfbb8 R08: 0000000000000001 R09: ffffffff88100d00
Apr 02 15:58:41 Enterprise-NAS kernel: R10: ffff88008debfb30 R11: 000000000000000b R12: 0000000000000001
Apr 02 15:58:41 Enterprise-NAS kernel: R13: ffff88013e28f100 R14: 0000000000000000 R15: 000000000000000f
Apr 02 15:58:41 Enterprise-NAS kernel: FS: 0000000000000000(0000) GS:ffff88014fc80000(0000) knlGS:0000000000000000
Apr 02 15:58:41 Enterprise-NAS kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Apr 02 15:58:41 Enterprise-NAS kernel: CR2: 00007ffdc7ac6f78 CR3: 0000000008cd6000 CR4: 0000000000000670
Apr 02 15:58:41 Enterprise-NAS kernel: Stack:
Apr 02 15:58:41 Enterprise-NAS kernel: ffff8800ab8b9080 0000000000000001 ffff88013e28f100 ffff88008debfbf8
Apr 02 15:58:41 Enterprise-NAS kernel: ffffffff88134fe0 000000010000000d ffff88013c380a80 ffff8800ab8b9080
Apr 02 15:58:41 Enterprise-NAS kernel: ffff88008debfc50 0000000000000001 ffff88009657ea68 ffff88008debfc18
Apr 02 15:58:41 Enterprise-NAS kernel: Call Trace:
Apr 02 15:58:41 Enterprise-NAS kernel: [<ffffffff88134fe0>] put_files_struct+0x65/0xad
Apr 02 15:58:41 Enterprise-NAS kernel: [<ffffffff881350a9>] exit_files+0x3c/0x41
Apr 02 15:58:41 Enterprise-NAS kernel: [<ffffffff88066034>] do_exit+0x3d7/0x8fc
Apr 02 15:58:41 Enterprise-NAS kernel: [<ffffffff880055d7>] oops_end+0x9d/0xa4
Apr 02 15:58:41 Enterprise-NAS kernel: [<ffffffff88005633>] die+0x55/0x5e
Apr 02 15:58:41 Enterprise-NAS kernel: [<ffffffff88003a26>] do_general_protection+0x8f/0x135
Apr 02 15:58:41 Enterprise-NAS kernel: [<ffffffff888eb072>] general_protection+0x22/0x30
Apr 02 15:58:41 Enterprise-NAS kernel: [<ffffffff88134ee0>] ? dup_fd+0x176/0x1e4
Apr 02 15:58:41 Enterprise-NAS kernel: [<ffffffff880625a2>] copy_process+0x5b1/0x1611
Apr 02 15:58:41 Enterprise-NAS kernel: [<ffffffff88094235>] ? vprintk_default+0x9/0xb
Apr 02 15:58:41 Enterprise-NAS kernel: [<ffffffff8811fc68>] ? get_empty_filp+0x141/0x185
Apr 02 15:58:41 Enterprise-NAS kernel: [<ffffffff881351e5>] ? __alloc_fd+0x137/0x167
Apr 02 15:58:41 Enterprise-NAS kernel: [<ffffffff88063744>] _do_fork+0x78/0x243
Apr 02 15:58:41 Enterprise-NAS kernel: [<ffffffff8806e9d8>] ? __set_current_blocked+0x3d/0x51
Apr 02 15:58:41 Enterprise-NAS kernel: [<ffffffff8806eb38>] ? sigprocmask+0x5b/0x5f
Apr 02 15:58:41 Enterprise-NAS kernel: [<ffffffff88063981>] SyS_clone+0x14/0x16
Apr 02 15:58:41 Enterprise-NAS kernel: [<ffffffff888e990a>] entry_SYSCALL_64_fastpath+0x1e/0x8e
Apr 02 15:58:41 Enterprise-NAS kernel: Code: 00 01 00 74 05 b8 02 00 00 00 41 0f ba e0 11 72 03 83 c8 01 48 8d 4d ec 89 45 fc e8 ff e6 00 00 c9 c3 55 48 89 e5 41 55 41 54 53 <48> 8b 47 38 48 85 c0 75 11 48 c7 c7 9f 45 b6 88 45 31 e4 e8 ef
Apr 02 15:58:41 Enterprise-NAS kernel: RIP [<ffffffff8811cabc>] filp_close+0x9/0x6f
Apr 02 15:58:41 Enterprise-NAS kernel: RSP <ffff88008debfba0>
Apr 02 15:58:41 Enterprise-NAS kernel: ---[ end trace 918f7e9d8e3bfb6c ]---
Apr 02 15:58:41 Enterprise-NAS kernel: Fixing recursive fault but reboot is needed!
-- Reboot --
Apr 02 16:13:18 Enterprise-NAS kernel: Initializing cgroup subsys cpuset
Apr 02 16:13:18 Enterprise-NAS kernel: Initializing cgroup subsys cpuacct
Apr 02 16:13:18 Enterprise-NAS kernel: Linux version 4.4.218.x86_64.1 (root@blocks) (gcc version 8.3.0 (Debian 8.3.0-6) ) #1 SMP Mon Mar 14 21:33:09 UTC 2022
Apr 02 16:13:18 Enterprise-NAS kernel: Command line: initrd=initrd.gz reason=normal BOOT_IMAGE=kernel
Apr 02 16:13:18 Enterprise-NAS kernel: KERNEL supported cpus:
Apr 02 16:13:18 Enterprise-NAS kernel: Intel GenuineIntel
Apr 02 16:13:18 Enterprise-NAS kernel: Disabled fast string operations
Apr 02 16:13:18 Enterprise-NAS kernel: x86/fpu: Legacy x87 FPU detected.
Apr 02 16:13:18 Enterprise-NAS kernel: e820: BIOS-provided physical RAM map:
Apr 02 16:13:18 Enterprise-NAS kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009cbff] usable
Apr 02 16:13:18 Enterprise-NAS kernel: BIOS-e820: [mem 0x000000000009cc00-0x000000000009ffff] reserved
Apr 02 16:13:18 Enterprise-NAS kernel: BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
Apr 02 16:13:18 Enterprise-NAS kernel: BIOS-e820: [mem 0x0000000000100000-0x00000000afeaffff] usable
Apr 02 16:13:18 Enterprise-NAS kernel: BIOS-e820: [mem 0x00000000afeb0000-0x00000000afebdfff] ACPI data
Apr 02 16:13:18 Enterprise-NAS kernel: BIOS-e820: [mem 0x00000000afebe000-0x00000000afeeffff] ACPI NVS
Apr 02 16:13:18 Enterprise-NAS kernel: BIOS-e820: [mem 0x00000000afef0000-0x00000000afefffff] reserved
Apr 02 16:13:18 Enterprise-NAS kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
Apr 02 16:13:18 Enterprise-NAS kernel: BIOS-e820: [mem 0x00000000ffb00000-0x00000000ffffffff] reserved
Apr 02 16:13:18 Enterprise-NAS kernel: BIOS-e820: [mem 0x0000000100000000-0x000000014fffffff] usable - SandsharkApr 02, 2023Sensei
The VGA will give you just a terminal.
I'm no expert here, but that sounds like you have a "tainted" kernel. That the LCD driver is what called it is likely irrelevant except that it is called due to specific actions. The VPD process is also linked, as it lets the OS know which kind of display you have, but I think you'd see a much worse situation if the VPD file were corrupt (NAS would not boot).
There may be a way to fix (replace?) the kernel via support mode, but that's not in my wheelhouse. And I would think an OS re-install would already do that.
I was trying to work out a way to do a full OS re-install and retain your data by EXPORTing your volume, using one drive to factory default, importing the original volume (less one drive, so degraded), then DESTROYing the new one. I did so on a new-to-me RN3220, but the OS and swap partitions didn't propagate to a RAID including all drives, they remained only on the single factory-defaulted drive. I could manually add the missing ones to the OS RAID via SSH, but not to the swap. After the DESTROY, there was no longer any swap partition (but the OS expected one) and things got completely locked up. I had expected the DESTROY to create a swap partition on the remaining drives. I had to factory default the whole thing just to boot -- an OS re-install wasn't enough. I plan to try again, disabling the swap partition and trying to add the other drives before the DESTROY. But with your situation, doing that could make things worse. And I'm busy doing other things with that NAS now.
Will I be able to plug a keyboard and use the terminal via VGA? If so, why not.
For now, I've unplugged the LCD screen. I also never realised that the flash memory is at the front of the unit and if you unplug both those IDC cables, the NAS won't boot. 🙂
I've also stopped nv6lcd. It might be nonsense but my NAS has been doing this for years - only not so frequently. Can I assume the LCD is a USB device? What if it's faulty and it's crashing the system?
I'll attempt an OS reinstall - if someone could confirm whether the link I quoted above is the correct procedure as I saw another one online which suggests that holding the reset button for long results in a factory reset... 🙂
And no worries Sandshark, I appreciate the thought. Unfortunately I am not incredibly skilled at Linux so I don't really want to try myself. If I had to factory reset the unit, I would look into an alternative software given that Netgear seems not to be very active with the development.
But I'd be very happy to just be able to use the NAS as it is 🙂
OK. I thought you'd already tried an OS re-install. Yes, that should have been the first thing to try. You will need to have the display re-connected when you do it, though. While units without a display use the system LEDs to let you choose menu items, those with a screen use only the screen, they don't also use the LEDs.
Don't worry about holding in the reset button too long. On a Pro6, that will make no difference. On units without a Backup button (rack-mount units), holding it longer makes it look for a USB recovery drive. But if one's not inserted, then that has no effect, except that it may have to be power cycled to boot (dunno, never tried it).
As StephenB said, you can use a USB keyboard with the VGA display to access the console. But as I said before, it doesn't gain you a lot in your case. It's more important if the NAS isn't booting to check BIOS settings and see the boot progress.
- tony359Apr 03, 2023Apprentice
Amazing thanks.
If it crashes again I'll surely do an OS reinstall. I'm putting the VGA adaptor together, I know it's a shot in the dark but it might give us more clues as when the box disappears from the network, there is still some activity in it (the "network has changed" message when I plug/unplug the ethernet cable).
Finger crossed, I'll keep you posted. Thanks for now.
- tony359Apr 04, 2023Apprentice
And the NAS "crashed" again unfortunately.
I went ahead and did an OS reinstall, which I doubt it helps as it looks like the current FW was reinstalled, nothing major.
Logs now show this:
Apr 03 23:21:42 Enterprise-NAS kernel: general protection fault: 0000 [#1] SMP
Apr 03 23:21:42 Enterprise-NAS kernel: Modules linked in: vpd(PO) [last unloaded: nv6lcd]
Apr 03 23:21:42 Enterprise-NAS kernel: CPU: 1 PID: 2508 Comm: bash Tainted: P O 4.4.218.x86_64.1 #1
Apr 03 23:21:42 Enterprise-NAS kernel: Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./To be filled by O.E.M., BIOS 080014 07/26/2010
Apr 03 23:21:42 Enterprise-NAS kernel: task: ffff8800aba90000 ti: ffff88010ef10000 task.ti: ffff88010ef10000
Apr 03 23:21:42 Enterprise-NAS kernel: RIP: 0010:[<ffffffff88134ee0>] [<ffffffff88134ee0>] dup_fd+0x176/0x1e4
Apr 03 23:21:42 Enterprise-NAS kernel: RSP: 0018:ffff88010ef13dc0 EFLAGS: 00010286Remember I manually unloaded nv6lcd yesterday.
I guess my next steps would be
- Try a different PSU. Which can be tricky as I am not sure I have a "known good" one 🙂 Does anybody remember what wattage the internal one is?
- Remove the drives, add a couple of spare, reset and test.
This is all very frustrating.
- StephenBApr 04, 2023Guru - Experienced User
tony359 wrote:- Remove the drives, add a couple of spare, reset and test.
I'd try this next. You haven't definitively ruled out a software issue.
tony359 wrote:- Try a different PSU. Which can be tricky as I am not sure I have a "known good" one 🙂 Does anybody remember what wattage the internal one is?
The hardware manual says 300W.
I know, it's just that removing my whole storage doesn't appeal me! 🙂 I'll see if I can do a partial backup so I can at least restore my document folder etc.
'cause yeah, the NAS has gone offline again, it only lasted a couple of hours. 😞
tony359 wrote:
I know, it's just that removing my whole storage doesn't appeal me! 😞
I get that, but am thinking that you will either end up with factory default or a new NAS. Just guessing that a new PSU won't solve it, and you've basically exhausted all the other hardware options.
So one way or another, you need to get as much data as you can backed up.
I can't disagree with you.
This issue has been going on forever, only happening every few months, not hours. A tired PSU could be a good scenario IMHO.
I shall try to populate the NAS with 6 HDD for my test as that would probably stress the PSU as much as my current setup (5 HDDs).
I wished there was an easier way to migrate to a different OS but by looking online I don't see easy paths.
- SandsharkApr 04, 2023Sensei
Your problem doesn't seem like a power supply issue to me. Periodic voltage droops could cause that, but it's just not a common failure mode. A failing capacitor in the supply might do it, and "bulging" capacitors are a common failure on some supplies, but there are no instances of it on a Pro6 I can recall.
The original power supply is 300W. But if you look at the voltage specs, it has more 12V current available than a typical 300W. I recommend at least a 350W replacement, and I typically use a 400W. I generally buy ones that have automatic fan speed control, which tends to keep them more quiet. You can connect a standard ATX12V supply externally and see if that fixes the issue. But in your case, you're going to need to run it a while, so be sure to keep the airflow as intact as possible. Sealing the fan opening for the original supply and the gap where the cables come out with masking tape will accomplish that.
