tony359
Mar 30, 2023Apprentice
ReadyNAS Pro 6 crashed again
Hello all, My ReadyNAS Pro6 periodically stops responding to the network. When that happens I can push the button to shutdown it but it will sit on "shutting down" forever and then I'll have to p...
tony359
Jun 05, 2023Apprentice
I do have SSH enabled! 🙂
I've just tested turning SSH off and on again but I still don't get an output.
I appreciate I only have DELL monitors but I never had issues with VGA. I even managed to display out of spec EGA signal on one of them!
I appreciate the hassle of having to dig out a Pro6. You have my appreciation if you could do it - but no hard feelings if you can't do it! 🙂
itachi2
Jun 06, 2023Tutor
I had sporadic network drops in my Pro 6 but I could reconnect via the second port. I could SSH again in that way but filesystem was unresponsive and shutdown would hang. I did have a btrfs error in the logs though and eventually ran an offline btrfs-check after booting from a live Debian USB that found one file that was often accessed was corrupt. I think I wound up deleting the file vs. having btrfs-check repair it -- this was a while back so details are a little hazy, but btrfs-check (or a scrub) eventually found it. There may have been a CSUM ref or two in the logs as well.
The only similarity may be the kernel fault that showed for me as well, but might be worth a filesystem check or two. Hope you get closer to an answer - my bug took months and I still have a remote power plug to cycle it when necessary.
