WaveX
Dec 03, 2017Aspirant
Readynas pro 6 dead
Hi everybody. 8 months ago i bought a Readynas 6 pro (used) and installed 6 3TB disks in it (2 spares). Everything worked perfect until 2 days ago. I knew the power was working but couldn't find ...
- Dec 09, 2017
I found a secondhand readynas Ultra 6 model. When i came home i removed all the drives - put my drives in (in the right order). I booted the machine and everything worked like a charm.
WaveX
WaveX
I just removed all the disk :
readyNAS on the display - no ethernet activity.
RAIDar doesn't find a thing...
Can i do a factory reset and then put the disks in or is my best option another device ? Because i found a
ReadyNAS Ultra 6 - an i just put my disks in and will they be available ?
thanks,
wavex
Dec 03, 2017Guru - Experienced User
No you can't. The factory reset installs the OS onto the hard drives, so it can't be done w/o the disks in place. And of course your unit won't even boot.
WaveX wrote:
i found a ReadyNAS Ultra 6 - an i just put my disks in and will they be available ?
You can (assuming the filesystems on the drives weren't damaged when the Pro failed). It's best to update the ultra so that it is running the same firmware as the pro-6 was before you migrate your disks. You'll need a temporary scratch disk installed when you do that. Then power down the replacement, and put all the disks from the pro into their corresponding slots in the ultra 6. After that, just power up.
It is also possible to temporarily mount the disks in a new x86 ReadyNAS (RN300 series or better): https://kb.netgear.com/29957/ReadyNAS-Migrating-disks-from-RAIDiator-4-2-to-ReadyNAS-OS-6-x86
- SandsharkDec 03, 2017Sensei
The unit will say "ReadyNAS" if there is just 5V power. So a lot could be wrong. But the power supply is the usual suspect. The 12V CPU power is a likely candidate with your symptoms. Of course, it could be something more substantial. Those units are getting old.
Since your current unit and the replacement are used, make sure thay are running the same firmware. Both those units shipped with OS4.2.x but can be upgraded to 6.x. Putting a 6.x drive set into a 4.2.x machine can be catastrophic, as the unit will re-format them. Putting an OS4.2.x drive set into an OS6.x unit will warn you the drives are used so they are formatted only if y9ou tell it to do so, but there is no way you can read the data on them. If the Pro was on OS6.x, then you could use an newer NAS than an Ultra, too.
