WaveX
Dec 03, 2017Aspirant
Readynas pro 6 dead
Hi everybody. 8 months ago i bought a Readynas 6 pro (used) and installed 6 3TB disks in it (2 spares). Everything worked perfect until 2 days ago. I knew the power was working but couldn't find ...
- Dec 09, 2017
I found a secondhand readynas Ultra 6 model. When i came home i removed all the drives - put my drives in (in the right order). I booted the machine and everything worked like a charm.
WaveX
WaveX
Dec 09, 2017Aspirant
WaveX
- SandsharkDec 09, 2017Sensei - Experienced User
Now that you are up and runing, you can investigate if it's just the power supply at fault. If you have an ATX supply around, or can "borrow" one from a PC, it can be connected externally to see if that fixes it. If it does, it could be worthwhile to purchase a replacement supply. They aren't very expensive
