imakarov
Nov 24, 2017Aspirant
ReadyNas Pro 6 Frontview empty page
I have a problem with accessing to the admin page in FrontView. Everything is blank, can't press any buttons (no action). But "shares" page is accessable, and I can change password on "pas...
- Dec 03, 2017
Finally, it's working!
I took R4toR6_latest.bin, renamed it to RAIDiator-x86-6.9.1.img and using RAIDiator 4.2 USB Flash Recovery made bootable USB drive. After USB recovery, I was finally able to get into web interface.
The only issue is about model and serial numbers. Any idea how to correct them?
Sandshark
Nov 24, 2017Sensei
An almost full OS partition can cause erratic behavior in the UI. Have you received any warniongs about that?
imakarov
Hi,
I don`t completly understand, where should I get warnings.
I can see some errors in browser's developer mode, like:
Cannot read property 'getElementsByTagName' of null (when page loads)
Cannot read property 'getApplicableGetUrl' of undefined (when I press buttons)
Cannot read property 'setPageDefaultsSync' of undefined (when I press buttons)
And some problems with certificate.
Also, I've tried different browsers (IE, Chrome, Opera, Firefox) and different compatibility modes in IE. And even workstation with an Windows XP as a system.
- StephenBNov 25, 2017Guru - Experienced User
They would have shown up before you had the problem - if you have email alerts configured, you would also have gotten warning emails.
Did you try rebooting the NAS? Also, did you enable SSH on system->settings->services?
- imakarovNov 29, 2017Aspirant
StephenB wrote:
imakarov wrote:I don`t completly understand, where should I get warnings.
I connected monitor to NAS, to see what happens during booting process, but I don't see anything interesting.
I can't configure nither email alerts, nor SSH, because I can't get into web interface menu.
- SandsharkNov 25, 2017Sensei
The warnings should be in the log.
Sandshark wrote:The warnings should be in the log.
If warnings are somewhere in web interface, I don't see them, because it is not working. I can try to get into TechSupport mode, maybe there will be logs I need to look at?
- StephenBDec 01, 2017Guru - Experienced User
Do you have a backup of your data?
