imakarov
Nov 24, 2017Aspirant
ReadyNas Pro 6 Frontview empty page
I have a problem with accessing to the admin page in FrontView. Everything is blank, can't press any buttons (no action). But "shares" page is accessable, and I can change password on "pas...
- Dec 03, 2017
Finally, it's working!
I took R4toR6_latest.bin, renamed it to RAIDiator-x86-6.9.1.img and using RAIDiator 4.2 USB Flash Recovery made bootable USB drive. After USB recovery, I was finally able to get into web interface.
The only issue is about model and serial numbers. Any idea how to correct them?
imakarov
Dec 02, 2017Aspirant
Also, I'm a bit confused, that RAIDar can't get it's model. Is it normal behavior?
imakarov
Dec 03, 2017Aspirant
- StephenBDec 03, 2017Guru - Experienced User
I think you'll need help from Netgear to do that. Since OS-6 isn't supported on legacy NAS, that will need to be courtesy support.
Try PMing mdgm-ntgr or Skywalker, and see if they are willing to log in remotely and help.
- mdgm-ntgrDec 03, 2017NETGEAR Employee Retired
I have replied to your PM.
- imakarovDec 03, 2017Aspirant
Replied PM
