J_Malmlund
Nov 30, 2021Tutor
ReadyNAS Pro 6 on readyos v6.10.6 no frontview on boot
First of all let me right of the bat start by acknowledge that I'm aware I'm running "unsupported" software on legacy hardware. My setup has been working good for years and years since I due to secu...
- Dec 02, 2021
Not a lot of clues here. You might want to search through all the log files and see if there is more information on what is killing apache. It might be one of the add-ons/apps (including ones you uninstalled that might not have uninstalled correctly).
The brute-force "fix" is to back up the files, do a factory default, rebuild the NAS, and then restore the data.
Dec 01, 2021Guru - Experienced User
Have you tried an OS reinstall from the boot menu?
- J_MalmlundDec 02, 2021TutorYes, I’ve tried the boot menu OS reinstall but that didn’t help which is so wired!
- StephenBDec 02, 2021Guru - Experienced User
Haha! Yes, the brute force method... :smileyvery-happy: well to be perfectly honest I've already ordered (and received) a new set of disks to do just that!
I have the disks but now that I'm about to start the process of cloning almost 40 Tb (got 6 x 14 Tb array of disks) from my "frontline NAS" (I have two Pro-6 units) to the one on the inner more protected network I realized that it's going to be days of clogging up the network.. :smileylol:
My question here was more like a "hail Mary" kind of "finding an easier way out" :smileytongue: :smileylol:
