SteveMathews
Nov 20, 2016Guide
ReadyNAS Pro 6 stuck at Booting...
Help! For a few days now my Pro 6 has been hanging on the boot screen at about 5% complete. Prior to this it has been stable for the last 3 months and hapily uploading/ synchronising to the A...
- Nov 22, 2016
SteveMathews wrote:
if these are any help
Not really, ls -i shows the inode for each file, but it doesn't give you the number of inodes used.
If you use dlna, then go into /var/cache and delete the contents of the dlna cache folder.
Then perhaps just try booting again.
Nov 20, 2016Guru - Experienced User
What firmware are you running?
- SteveMathewsNov 20, 2016Guide
sorry, yes should have added it's on 6.6.0
thanks
Steve
- StephenBNov 21, 2016Guru - Experienced User
Was ssh enabled? If so, see if you can log in that way.
- SteveMathewsNov 21, 2016Guide
ssh was enabled but unfortunately it doesn't get far enought in the boot process to allow me to access with ssh
