SteveMathews
Nov 20, 2016Guide
ReadyNAS Pro 6 stuck at Booting...
Help! For a few days now my Pro 6 has been hanging on the boot screen at about 5% complete. Prior to this it has been stable for the last 3 months and hapily uploading/ synchronising to the A...
- Nov 22, 2016
SteveMathews wrote:
if these are any help
Not really, ls -i shows the inode for each file, but it doesn't give you the number of inodes used.
If you use dlna, then go into /var/cache and delete the contents of the dlna cache folder.
Then perhaps just try booting again.
Nov 21, 2016Guru - Experienced User
I could be wrong here, since I am not running OS 6 on my pro. But my understanding was that the conversion process also upgraded the boot loader. Perhaps mdgm-ntgr will chime in.
Maybe try the boot menu, and see what options are presented on the LCD??? If you don't see the "volume read-only", then maybe try "Skip Volume Check".
Going in via tech support mode might be needed to assess the OS partition - you can then log in via telnet and manually mount it. But that's messy.
SteveMathews
Nov 21, 2016Guide
I can't see a read-only option and running the 'skip volume check' it still hangs on boot and it not accessable from ssh.
are there any instructions for how to go in via tech support mode?
thanks
steve
- StephenBNov 21, 2016Guru - Experienced User
Here's a link that might help: https://onlyblueatwork.wordpress.com/2012/12/04/netgear-readynas-access-recovery/
Disclaimer: I've never needed to do it myself.
- mdgm-ntgrNov 21, 2016NETGEAR Employee Retired
Let us know how you get on. It's quite possible the problem could be a full 4GB root volume, but it could also be something else again.
- SteveMathewsNov 22, 2016Guide
I may be getting somewhere but i keep getting kicked-out
Welcome to Secure Shell version 0.8.34.4. Answers to Frequently Asked Questions: https://goo.gl/muppJj [Pro Tip] Use 'Open as Window' to keep Control-W from closing your terminal! [Pro Tip] See https://goo.gl/muppJj for more information. Connecting to root/[email protected], port 23... Loading NaCl plugin... done. ssh_exchange_identification: Connection closed by remote host NaCl plugin exited with status code 255. (R)econnect, (C)hoose another connection, or E(x)it? Connecting to root/[email protected], port 23... Loading NaCl plugin... done. ssh_exchange_identification: Connection closed by remote host NaCl plugin exited with status code 255. (R)econnect, (C)hoose another connection, or E(x)it?
Any ideas?
thanks
Steve
scrub that last comment - i was being a muppet!
Now i'm using telnet i'm in and have successfully mounted the drive
/dev/md0 is size 4.90G, used 2.9G Available 721.1M 81% used
is this full enough to prevent booting - i seem to recall in recent times it has been at about the 70-80% level....
thanks
steve
- StephenBNov 22, 2016Guru - Experienced User
It is still quite full - mine runs at ~40% full with Crashplan installed.
Check the inode usage also (df . -i)
when i run df -i it returns
df: invalid operation --i
does this mean the coreutils is not up to date?
i'm very rusty with linux so i'll need to look up some navigation commands before i go hunting around for the space-wasting files.
do you know where i'm likley to find the log files (most likely for amazon cloud sync) (and how to navigate there!)
thanks again
Steve
You need a path (which I left out). For instance df . -i ought to give you the inode usage of the file system you are in.
I still have a problem running this
# cd # pwd /root # df . -i df: invalid option -- i BusyBox v1.24.1 (2016-09-16 09:58:20 PDT) multi-call binary. Usage: df [-PkmhT] [FILESYSTEM]...
I did manage to get ls -i working though
# ls -i 19 bin 417 init 256 mnt 176 run 213 tmp 3 dev 123 lib 169 opt 177 sbin 214 usr 66 etc 416 lib64 1 proc 1 sys 407 var 122 home 167 media 18 root 212 sysrootand ls -l
# ls -l drwxr-xr-x 2 940 Sep 23 18:46 bin drwxr-xr-x 13 3280 Nov 22 14:06 dev drwxr-xr-x 11 820 Nov 22 14:06 etc drwxr-xr-x 2 40 Sep 16 11:08 home -rwxr-xr-x 1 74336 Sep 23 18:46 init drwxr-xr-x 4 760 Sep 23 18:46 lib lrwxrwxrwx 1 3 Sep 16 10:52 lib64 -> lib drwxr-xr-x 3 60 Nov 22 12:44 media drwxr-xr-x 1 302 Nov 18 17:06 mnt drwxr-xr-x 2 40 Sep 16 10:46 opt dr-xr-xr-x 118 0 Nov 22 12:44 proc drwx------ 3 140 Nov 22 15:28 root drwxr-xr-x 3 100 Nov 22 14:06 run drwxr-xr-x 2 700 Sep 23 18:46 sbin dr-xr-xr-x 12 0 Nov 22 12:44 sys drwxr-xr-x 2 40 Sep 16 10:46 sysroot drwxrwxrwt 2 60 Nov 22 12:44 tmp drwxr-xr-x 6 140 Sep 16 11:08 usr drwxr-xr-x 6 120 Sep 26 18:53 var
Bingo!
It's working now!
The worst files seemed to be in my squeezebox lib folder
artwork - 200Mb, and
spotify cache - 150Mb
I deleted both of these and it seems to be booting-up fine now.
I've ssh'd back in and the 4G partition is now at 71% which is higher than i'd like so i'll do a bit more digging over the next few days
But i'm just relieved to have got it back up
Thanks v much StephenB
Steve
SteveMathews wrote:
It's working now!
Great! Glad I was able to help.
