SteveMathews
Nov 20, 2016Guide
ReadyNAS Pro 6 stuck at Booting...
Help! For a few days now my Pro 6 has been hanging on the boot screen at about 5% complete. Prior to this it has been stable for the last 3 months and hapily uploading/ synchronising to the A...
- Nov 22, 2016
SteveMathews wrote:
if these are any help
Not really, ls -i shows the inode for each file, but it doesn't give you the number of inodes used.
If you use dlna, then go into /var/cache and delete the contents of the dlna cache folder.
Then perhaps just try booting again.
Nov 21, 2016Guru - Experienced User
Here's a link that might help: https://onlyblueatwork.wordpress.com/2012/12/04/netgear-readynas-access-recovery/
Disclaimer: I've never needed to do it myself.
SteveMathews
Nov 22, 2016Guide
I may be getting somewhere but i keep getting kicked-out
Welcome to Secure Shell version 0.8.34.4. Answers to Frequently Asked Questions: https://goo.gl/muppJj [Pro Tip] Use 'Open as Window' to keep Control-W from closing your terminal! [Pro Tip] See https://goo.gl/muppJj for more information. Connecting to root/infr8ntdebug@192.168.0.51, port 23... Loading NaCl plugin... done. ssh_exchange_identification: Connection closed by remote host NaCl plugin exited with status code 255. (R)econnect, (C)hoose another connection, or E(x)it? Connecting to root/infr8ntdebug@192.168.0.51, port 23... Loading NaCl plugin... done. ssh_exchange_identification: Connection closed by remote host NaCl plugin exited with status code 255. (R)econnect, (C)hoose another connection, or E(x)it?
Any ideas?
thanks
Steve
