SteveMathews
Nov 20, 2016Guide
ReadyNAS Pro 6 stuck at Booting...
Help! For a few days now my Pro 6 has been hanging on the boot screen at about 5% complete. Prior to this it has been stable for the last 3 months and hapily uploading/ synchronising to the A...
- Nov 22, 2016
SteveMathews wrote:
if these are any help
Not really, ls -i shows the inode for each file, but it doesn't give you the number of inodes used.
If you use dlna, then go into /var/cache and delete the contents of the dlna cache folder.
Then perhaps just try booting again.
mdgm-ntgr
Nov 22, 2016NETGEAR Employee Retired
Let us know how you get on. It's quite possible the problem could be a full 4GB root volume, but it could also be something else again.
SteveMathews
Nov 22, 2016Guide
scrub that last comment - i was being a muppet!
Now i'm using telnet i'm in and have successfully mounted the drive
/dev/md0 is size 4.90G, used 2.9G Available 721.1M 81% used
is this full enough to prevent booting - i seem to recall in recent times it has been at about the 70-80% level....
thanks
steve
- StephenBNov 22, 2016Guru - Experienced User
It is still quite full - mine runs at ~40% full with Crashplan installed.
Check the inode usage also (df . -i)
- SteveMathewsNov 22, 2016Guide
when i run df -i it returns
df: invalid operation --i
does this mean the coreutils is not up to date?
i'm very rusty with linux so i'll need to look up some navigation commands before i go hunting around for the space-wasting files.
do you know where i'm likley to find the log files (most likely for amazon cloud sync) (and how to navigate there!)
thanks again
Steve
You need a path (which I left out). For instance df . -i ought to give you the inode usage of the file system you are in.
I still have a problem running this
# cd # pwd /root # df . -i df: invalid option -- i BusyBox v1.24.1 (2016-09-16 09:58:20 PDT) multi-call binary. Usage: df [-PkmhT] [FILESYSTEM]...
I did manage to get ls -i working though
# ls -i 19 bin 417 init 256 mnt 176 run 213 tmp 3 dev 123 lib 169 opt 177 sbin 214 usr 66 etc 416 lib64 1 proc 1 sys 407 var 122 home 167 media 18 root 212 sysroot
and ls -l
# ls -l drwxr-xr-x 2 940 Sep 23 18:46 bin drwxr-xr-x 13 3280 Nov 22 14:06 dev drwxr-xr-x 11 820 Nov 22 14:06 etc drwxr-xr-x 2 40 Sep 16 11:08 home -rwxr-xr-x 1 74336 Sep 23 18:46 init drwxr-xr-x 4 760 Sep 23 18:46 lib lrwxrwxrwx 1 3 Sep 16 10:52 lib64 -> lib drwxr-xr-x 3 60 Nov 22 12:44 media drwxr-xr-x 1 302 Nov 18 17:06 mnt drwxr-xr-x 2 40 Sep 16 10:46 opt dr-xr-xr-x 118 0 Nov 22 12:44 proc drwx------ 3 140 Nov 22 15:28 root drwxr-xr-x 3 100 Nov 22 14:06 run drwxr-xr-x 2 700 Sep 23 18:46 sbin dr-xr-xr-x 12 0 Nov 22 12:44 sys drwxr-xr-x 2 40 Sep 16 10:46 sysroot drwxrwxrwt 2 60 Nov 22 12:44 tmp drwxr-xr-x 6 140 Sep 16 11:08 usr drwxr-xr-x 6 120 Sep 26 18:53 var
Bingo!
It's working now!
The worst files seemed to be in my squeezebox lib folder
artwork - 200Mb, and
spotify cache - 150Mb
I deleted both of these and it seems to be booting-up fine now.
I've ssh'd back in and the 4G partition is now at 71% which is higher than i'd like so i'll do a bit more digging over the next few days
But i'm just relieved to have got it back up
Thanks v much StephenB
Steve
SteveMathews wrote:
It's working now!
Great! Glad I was able to help.
