SteveMathews
Nov 20, 2016Guide
ReadyNAS Pro 6 stuck at Booting...
Help! For a few days now my Pro 6 has been hanging on the boot screen at about 5% complete. Prior to this it has been stable for the last 3 months and hapily uploading/ synchronising to the A...
- Nov 22, 2016
SteveMathews wrote:
if these are any help
Not really, ls -i shows the inode for each file, but it doesn't give you the number of inodes used.
If you use dlna, then go into /var/cache and delete the contents of the dlna cache folder.
Then perhaps just try booting again.
Nov 22, 2016Guru - Experienced User
SteveMathews wrote:
when i run df -i it returns
df: invalid operation --i
You need a path (which I left out). For instance df . -i ought to give you the inode usage of the file system you are in.
SteveMathews
Nov 22, 2016Guide
I still have a problem running this
# cd # pwd /root # df . -i df: invalid option -- i BusyBox v1.24.1 (2016-09-16 09:58:20 PDT) multi-call binary. Usage: df [-PkmhT] [FILESYSTEM]...
