SteveMathews
Nov 20, 2016Guide
ReadyNAS Pro 6 stuck at Booting...
Help! For a few days now my Pro 6 has been hanging on the boot screen at about 5% complete. Prior to this it has been stable for the last 3 months and hapily uploading/ synchronising to the A...
- Nov 22, 2016
SteveMathews wrote:
if these are any help
Not really, ls -i shows the inode for each file, but it doesn't give you the number of inodes used.
If you use dlna, then go into /var/cache and delete the contents of the dlna cache folder.
Then perhaps just try booting again.
SteveMathews
Nov 22, 2016Guide
I did manage to get ls -i working though
# ls -i
19 bin 417 init 256 mnt 176 run 213 tmp
3 dev 123 lib 169 opt 177 sbin 214 usr
66 etc 416 lib64 1 proc 1 sys 407 var
122 home 167 media 18 root 212 sysrootand ls -l
# ls -l drwxr-xr-x 2 940 Sep 23 18:46 bin drwxr-xr-x 13 3280 Nov 22 14:06 dev drwxr-xr-x 11 820 Nov 22 14:06 etc drwxr-xr-x 2 40 Sep 16 11:08 home -rwxr-xr-x 1 74336 Sep 23 18:46 init drwxr-xr-x 4 760 Sep 23 18:46 lib lrwxrwxrwx 1 3 Sep 16 10:52 lib64 -> lib drwxr-xr-x 3 60 Nov 22 12:44 media drwxr-xr-x 1 302 Nov 18 17:06 mnt drwxr-xr-x 2 40 Sep 16 10:46 opt dr-xr-xr-x 118 0 Nov 22 12:44 proc drwx------ 3 140 Nov 22 15:28 root drwxr-xr-x 3 100 Nov 22 14:06 run drwxr-xr-x 2 700 Sep 23 18:46 sbin dr-xr-xr-x 12 0 Nov 22 12:44 sys drwxr-xr-x 2 40 Sep 16 10:46 sysroot drwxrwxrwt 2 60 Nov 22 12:44 tmp drwxr-xr-x 6 140 Sep 16 11:08 usr drwxr-xr-x 6 120 Sep 26 18:53 var
Nov 22, 2016Guru - Experienced User
- SteveMathewsNov 22, 2016Guide
Bingo!
It's working now!
The worst files seemed to be in my squeezebox lib folder
artwork - 200Mb, and
spotify cache - 150Mb
I deleted both of these and it seems to be booting-up fine now.
I've ssh'd back in and the 4G partition is now at 71% which is higher than i'd like so i'll do a bit more digging over the next few days
But i'm just relieved to have got it back up
Thanks v much StephenB
Steve
- StephenBNov 22, 2016Guru - Experienced User
SteveMathews wrote:
It's working now!
Great! Glad I was able to help.
