ephemeris's avatar
ephemeris
ReadyNAS Pro 6 Upgrade from 4.2.28 to OS6 fail repeatedly
This is confusing. I converted my other Pro 6 from 4.2.26 to OS6 back in the winter without too much grief.  Now following AMRivlin's instructions OS6-now-works-on-x86-Legacy results in the machine c...
  • mdgm-ntgr's avatar
    Aug 17, 2016
    Try doing a factory reset then
    1. Install the Prep add-on
    2. Install the R4toR6 firmware image and when prompted reboot.
    3. The NAS should put OS6 on the flash and at the appropriate time trigger a factory reset.
    When using the prep add-on you don't need to do a manual factory reset. Just do the reboot when prompted as mentioned above and be patient. The NAS will reboot itself multiple times.
    If you don't install the Prep add-on after the R4toR6 firmware image has tried to install OS6 over the top of RAIDiator it will try to boot up but with a mixture of the two OSes it won't be able to come up properly (it reboots itself a few times or so before it gets to this point, if I recall correctly). At which point you would then power down and do a manual factory default.
ProSupport for Business
