tkeeler1
Jul 19, 2014Aspirant
ReadyNas Pro 6 Upgrade Recommendations
Hello, I currently use a Pro 6 (4.2.26), with 6x3TB drives using X-RAID2 (with dual redundancy). I'm nearing 70% capacity and I'm trying to plan for my next upgrade path. Any advice and answers you...
Jul 19, 2014Guru - Experienced User
Average operating power for the Seagate 6TB drives is spec'd at ~11 watts. HGST is spec'd around 7.
For comparison, 4 TB Seagate enterprise drives are spec'd at ~8 watts and the NAS drives are spec'd at ~4.
