tkeeler1
Jul 19, 2014Aspirant
ReadyNas Pro 6 Upgrade Recommendations
Hello, I currently use a Pro 6 (4.2.26), with 6x3TB drives using X-RAID2 (with dual redundancy). I'm nearing 70% capacity and I'm trying to plan for my next upgrade path. Any advice and answers you...
Jul 19, 2014Guru - Experienced User
The 11wt number is for the enterprise drive and comes from here: http://www.seagate.com/ca/en/internal-h ... hdd/#specs
The ST5000DM000 is 7.5 wt, the 4 TB model (ST4000DM000) is the one that is 5.6. (http://www.seagate.com/ca/en/support/in ... hdd/#specs). I'm not seeing a power spec for the STBD6000100. I wouldn't assume it is the same as the 5 TB version.
Some reviews mention that they "run hot", that they do not have the middle mounting screws, and that they are a bit oversized - you can read them here: http://www.newegg.com/Product/Product.a ... -_-Product
Amazon reviews mix up multiple models in the same thread, so they are not as useful to browse.
