geoffcooper's avatar
geoffcooper
ReadyNas Pro 6 v2 - stuck in "booting" after attempted log download #26682838
Hi,   Product Model: ReadyNASRNDP6000v2 Serial Number: 2H0627RK0007B Firmware: 4.2.27   I see there have been support issuse like this in the past that were solved by Netgear - this morni...
  • JennC's avatar
    JennC
    Mar 31, 2016
    Hello geoffcooper,
    That is not good then. Unfortunately, you may really need to get to support center, they may be able to fix this from the backend. Through support center they have L3 who remotes in to the NAS and fix it via Telnet. I checked your case submission and found that it is empty and there is no serial number registered, it needs serial number. Also, per incident support contract is needed for them to proceed.
ProSupport for Business
