kanouti
May 06, 2023Aspirant
ReadyNAS Pro 6 won't turn on
Hi community gurus, I figure this might be a long-shot, but it's worth a last-ditch effort. I recently went to turn on my NAS and found no response. Pressing the power button has no effect. There...
Sandshark
May 07, 2023Sensei
This does sound like a power supply issue, and that's the most common failure of that model. A standard ATX12V supply works just fine when connected externally, and that's the best way to see if the PSU is the problem. Testing a power supply without a load is really not a very good test. It could give you insight, but may also make you think the supply is fine when it's not.
The supply is a standard SFX format one, but has a longer 24-pin cable and more 4-pin MOLEX than most. While it's rated at 300W, the 12V rail is more akin to most 400W ones. While I used to recommend you buy a400W or larger SFX supply and cable adapters, there is a seller on eBay that has some that already have the right cables and they've lowered the price to where that's now my recommendation.
kanouti
May 07, 2023Aspirant
Thanks Sandshark. I'm currently seeking a suitable test PSU to verify if it is a power rail issue - just have to find one with a 24pin connector. Tests of the stock PSU were performed both with and without load. The PSU line of enquiry is the best lead so far.
Ever since the VPD corrupted itself a few years ago, this system has left me waiting for the other shoe to drop. There's always the question of "Will it boot this time?".
