steveoelliott
Nov 03, 2015Luminary
Readynas Pro 6 X-RAID 2 Dual Redundancy Proactive Drive Swap
Hi all, I have a Pro 6 running 4.2.27 with 4x1TB Hitachi drives (approved on HCL) and am planning to proactively replace 2 of them so from a mechanical / wear perspective the drives in the volume...
- Nov 04, 2015
Hello steveoelliott,
I see. It should still be one at a time, same procedure with expansion. Replace one, let it resync and once done, replace the next disk and so on and so forth.
This might help: How do I replace a disk in my ReadyNAS Ultra, Ultra Plus, NVX or Pro series storage system?
JennC
Nov 03, 2015NETGEAR Employee Retired
We always strongly recommend to have full backup of important data.
Volume expansion may take a day for each disk, depending on how large the volume is. You may visit How do I vertically expand an X-RAID 2 volume on my ReadyNAS OS 6 storage system? article.
- steveoelliottNov 04, 2015Luminary
Hi,
I will be using identical drives for replacement so there should not be any expansion... Just a re-sync.
I presume this should be faster...
Thanks...
- JennCNov 04, 2015NETGEAR Employee Retired
- steveoelliottNov 17, 2015Luminary
All - Just so I have an idea of the time involved, how long ball park would an X-RAID 2 rebuild take on a pro 6 after I swap one of the disks? I will do this one at a time.
I have 4x1TB in an X-RAID2 dual redundancy and am looking to proactively swap two of them so mechanically the disks are different from a wear perspective. I have exactly the same models since I kept some back when the installation was initially completed.
