SolwayMist's avatar
SolwayMist
ReadyNas Pro 6
I'm upgrading my ReadyNas Pro 6 from Radiator 4.2. to OS6   I currently use the Logitech Media Server on my ReadyNas under Radiator 4.2 with a number of Logitech SqueezeBox clients. Will I be able...
  • JennC's avatar
    JennC
    Jul 10, 2017
    Hello SolwayMist,
    We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
    If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
    The Netgear community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
