Daz_ReadyNAS
Aug 28, 2017Aspirant
ReadyNAS Pro Battery Replacement
Hi ReadyNAS Community, We are using a ReadyNAS Pro 6310 (1Gb, Firmware RAIDiator 4.2.31). It was purchased from new in 2010 (now ~ 7.5 years old). The on-board battery has never been replace...
mdgm-ntgr
Aug 28, 2017NETGEAR Employee Retired
If the battery's dead you'd like see a number of weird time changes. After powering off the system for a while and turning it back on the time would revert to a really old date.
1. No
3. We don't support replacing it. However you'd power off the system, disconnect it from power and know what you're doing and you could replace it at your own risk. The battery is used e.g. for storing the time. Your settings are stored on the disks.
Sandshark
Aug 30, 2017Sensei
I purchased a used one and didn't initially realize the prior owner had removed the battery for storage. Other than showing an odd date and time at boot in the log, it worked perfectly fine. Once booted and time sync'ed to an NNTP server, even the time was right.
