marioscimone
Jun 18, 2019Aspirant
ReadyNAS Pro Business Edition RAIDiator 4.2.27
I had my nas running with 6 WDC WD1002FBYS-02A6B0 931 GB then I decided to upgrade and running X-raid I changed one by one each HD with new one WDC WD30EFRX-68EUZN0 2794 GB Everything was smooth ...
Sandshark
Jun 19, 2019Sensei
Since you replaced them one at a time, they are not in sync with each other. This is normal RAID behavior. If you had a need to go back to them, you would have needed to remove them all with power off and start over with new drives.
marioscimone
Jun 19, 2019Aspirant
Thank you for answer, so I have no chance to get the data back, the only thing I can do with the old disk is to use them as new and create a new raid with them, right?
- StephenBJun 19, 2019Guru - Experienced User
Correct. Or re-purpose them in some other way.
