pszilard
Apr 17, 2015Aspirant
ReadyNAS PRO Business unusable
I have a ReadyNAS Pro Businesss with 2GB RAM and 6x 2TB WD Red drives. It has the current OS, which I think is 4.2.27 It is backed up to a ReadyNAS Pro4, twice weekly, using rsync. (Thank God for thi...
RX
Apr 17, 2015Luminary
What if you try to pull-out the 2TB WD Red drive from the 6th bay? Check if your Pro Business will boot up normally with the remaining 5 disks inside.
Run an Extended test on the 2TB WD Red drive using the WD Data Lifeguard Diagnostic for Windows:
http://support.wdc.com/product/download ... =612&sid=3
