netracer
Aug 05, 2015Apprentice
ReadyNAS Pro keeps rebooting after shutdown
Regardless of whether I press the physical power button or execute a shutdown in the GUI, the device turns off and about 10 seconds later starts itself back up again. I had this problem once before ...
rantech
Oct 06, 2015Aspirant
Thanks for the reply. I have ordered a new power supply and am waiting for it to arrive to give it a try. My unit still powers up with the original PS so the only way I can see to test is to install the new PS then fully power up then shutdown and see what happens. However I'm leaning more towards a memory problem given the software issues I'm seeing. Memory could account for that but not sure the PS could?
I do have the latest firmware installed and this problem just suddenly cropped up. box had run steady for at least 8 months with everything working then I tried to shutdown and it immediately started rebooting so I pulled the power cord. After relocating and rebooting, squeeze Center no longer worked.
Oct 07, 2015Guru - Experienced User
You can run the memory test from the boot menu. If you have ssh installed, you can check for a filling OS partition (and also use top to look at current memory usage).
Memory for the pro/ultra is older technology, and getting expensive.
- rantechOct 09, 2015Aspirant
I managed to get the new power supply installed today and the problems have cleared so it was the power supply. For good measure, I purchased some replacement memory as well but I didn't need to use it. Will save it in case I need to replace that in the future as well.
Thanks to all the folks who responded.
