netracer
Aug 05, 2015Apprentice
ReadyNAS Pro keeps rebooting after shutdown
Regardless of whether I press the physical power button or execute a shutdown in the GUI, the device turns off and about 10 seconds later starts itself back up again. I had this problem once before ...
Oct 07, 2015Guru - Experienced User
rantech wrote:
However I'm leaning more towards a memory problem given the software issues I'm seeing. Memory could account for that but not sure the PS could?
You can run the memory test from the boot menu. If you have ssh installed, you can check for a filling OS partition (and also use top to look at current memory usage).
Memory for the pro/ultra is older technology, and getting expensive.
rantech
Oct 09, 2015Aspirant
I managed to get the new power supply installed today and the problems have cleared so it was the power supply. For good measure, I purchased some replacement memory as well but I didn't need to use it. Will save it in case I need to replace that in the future as well.
Thanks to all the folks who responded.
