greenleaf-noho
Dec 28, 2015Aspirant
ReadyNAS Pro Pioneer - Cannot allocate memory failure
I have a ReadyNAS Pro Pioneer (RNDP600E-100NAS) that is running on firmware version RAIDiator 4.2.28 with memory of 1024 MB [4-5-5-15 DDR2] with 2 - 1.5TB Seagate Barracuda SATA 7200 RPM, 32MB (ST315...
- Jan 02, 2016
Perhaps try this registry settings change?: http://superuser.com/questions/362331/cannot-allocate-memory-moving-files-over-network-share
greenleaf-noho
Jan 02, 2016Aspirant
Ok, thanks for the clarification. We thought that's what it meant but we didn't see the link on top. So I checked the messaging option, I am not sure how to attach 61 log files, sorry for the confusion on my part.
Jan 02, 2016Guru - Experienced User
You'd need to save them on a server somewhere (put a zip in google drive for instance) and put a link in the PM.
- mdgm-ntgrJan 02, 2016NETGEAR Employee Retired
- greenleaf-nohoJan 03, 2016Aspirant
Update: These changes appeared to have helped significantly. The backup ran for nearly 6 hours, however there was an errror message again. Zipped log file will be PM'd.
When I compare the file quantity on the source to the backup it was 7 files short (~4MB worth) out of the 101,147 total files.
I think I am close to having a successful backup, but I can't locate the error message to see if there was/is a problem.
Thanks for all of the help.
- mdgm-ntgrJan 03, 2016NETGEAR Employee Retired
All the backup job logs I can see are from late December.
Which backup job number are you using? - greenleaf-nohoJan 03, 2016Aspirant
Number 5 at that time.
I forgot to check my email for the error list, this is what I got:
cp: cannot create regular file '/job_005//backup/./Andrew\'s PC/MY DOCUMENTS on PIII-933 (Andrew)/Genealogy/Philip Hamel\'s side of the family (Hamel, Champagne, Cloutier, Beauchamp, Lacombe)/Scanned Images/1880FE~3.BMP': File exists
cp: cannot create regular file '/job_005//backup/./Andrew\'s PC/MY DOCUMENTS on PIII-933 (Andrew)/Genealogy/Barbara (Horne) Hamel\'s side of the family (Horne, Mazeski, McIntosh, Skinner)/Scanned Images/2001-1~2.JPG': File exists
cp: cannot create regular file '/job_005//backup/./Andrew\'s PC/MY DOCUMENTS on PIII-933 (Andrew)/Genealogy/Barbara (Horne) Hamel\'s side of the family (Horne, Mazeski, McIntosh, Skinner)/Scanned Images/1928-1~1.JPG': File exists
cp: cannot create regular file '/job_005//backup/./Andrew\'s PC/MY DOCUMENTS on PIII-933 (Andrew)/Genealogy/Barbara (Horne) Hamel\'s side of the family (Horne, Mazeski, McIntosh, Skinner)/Scanned Images/1987-0~2.JPG': File exists
cp: cannot create regular file '/job_005//backup/./Andrew\'s PC/MY DOCUMENTS on PIII-933 (Andrew)/Genealogy/Barbara (Horne) Hamel\'s side of the family (Horne, Mazeski, McIntosh, Skinner)/Scanned Images/2001-1~1.JPG': File exists
cp: cannot create regular file '/job_005//backup/./Andrew\'s PC/MY DOCUMENTS on PIII-933 (Andrew)/Genealogy/Barbara (Horne) Hamel\'s side of the family (Horne, Mazeski, McIntosh, Skinner)/Scanned Images/2001-1~3.JPG': File exists
Which oddly enough adds up to 6 files, 1 short of the 7 differential.
I have since removed this files and I am running another complete backup to test, previous changes. Backup started at 4:12 PM EST, so should be finished between 10 and 11. More to come
- greenleaf-nohoJan 04, 2016Aspirant
Previous backup attempt also had errors because the offending files when copied and then deleted were transferred to the recycle bin. I removed them from the recycle bin and reran backup this morning with complete success after 6 hours.
One other backup related question... is it okay to use (read/write) the fileserver while the backup is running?
- StephenBJan 05, 2016Guru - Experienced User
I've had backups fail when files are deleted on the source while the backup is running (though whether that happens might depend on the specific backup protocol being used). So updating files is best avoided.
There are no issues if the files are simply being read.
