reburns
Dec 25, 2021Aspirant
ReadyNAS Pro Pioneer drive not adding (RNDP600E)
Hello & happy summery winter Saturday! Question on Pro Pioneer 6.9.6
I have hot removed a 16TB WD Red Pro HDD in slot #2 and added a brand new 18TB WD181KFGX, however the volume is not rebuild...
Dec 25, 2021Guru - Experienced User
There are errors in the log files for the new disk
Dec 25 09:55:22 Ascent-Pioneer kernel: ata2.00: failed command: SMART Dec 25 09:55:22 Ascent-Pioneer kernel: ata2.00: cmd b0/d0:01:00:4f:c2/00:00:00:00:00/00 tag 5 pio 512 in res 53/10:00:00:00:00/00:00:00:00:00/00 Emask 0x81 (invalid argument)
Dec 25 09:53:09 Ascent-Pioneer kernel: ata2.00: status: { DRDY ERR }
Dec 25 09:53:09 Ascent-Pioneer kernel: ata2.00: error: { IDNF }
Dec 25 09:53:09 Ascent-Pioneer kernel: do_marvell_9170_recover: ignoring PCI device (8086:2821) at PCI#0
Dec 25 09:53:09 Ascent-Pioneer kernel: ata2.00: failed to enable AA (error_mask=0x1)
I suggest testing the disk in a PC with WDC's dashboard program.
BTW, you shouldn't post the log zip publicly - there is privacy leakage when you do that. I've redacted your link.
reburns
Thank you times two Stephen!
Q: Can I re-insert the old HDD back into that slot 2 and get redundency back in the meantime??
- StephenBDec 25, 2021Guru - Experienced User
You can, but I suggest deleting the partitions first. Then it should automatically start resyncing when you hot-insert it.
- reburnsDec 26, 2021Aspirant
RE: Old drive. Duh, I wasn't thinking of rebuilding, just replacing intact as if there'd been no data change. The partitions were wiped and it's rebuilding now. That will take more than a day.
Connecting the suspect new 18TB drive to a Win10 PC via USB-SATA adapter and using the WD Diagnostics reveals only passing scores for the quick, extended and write zero tests. If's it's even a little suspect then I'd seek a replacement, but not sure if that's possible with passing scores?
- StephenBDec 26, 2021Guru - Experienced User
You likely can exchange it with the seller.
Did you check the smart stats? Or are you just trusting the pass/fail score?
