reburns
Dec 25, 2021Aspirant
ReadyNAS Pro Pioneer drive not adding (RNDP600E)
Hello & happy summery winter Saturday! Question on Pro Pioneer 6.9.6
I have hot removed a 16TB WD Red Pro HDD in slot #2 and added a brand new 18TB WD181KFGX, however the volume is not rebuild...
Jan 14, 2022Guru - Experienced User
reburns wrote:
What log file would help show which disk?
Maybe see if there is more in system.log???
reburns
Jan 14, 2022Aspirant
Is this a safe upload? Attached system.log
On the 30th power went down as I was off on fire duty... 1,100 homes burned
- StephenBJan 15, 2022Guru - Experienced User
looks ok - a couple of your file names are in there, but that's the only privacy leakage I see.
I am seeing a photo that failed to copy at the time of the BTRFS errors - but no disk errors. It is possible that there is some file system corruption (in which case the disks might be fine).
Marshall? Really terrible.
- reburnsJan 15, 2022AspirantYes, Marshall / Middle Fork. My other truck.
- reburnsJan 24, 2022Aspirant
In this case, third try is the charm and the 18TB rebuilt into slot #2. Now I know to save some trouble if there's no SMART reading using a USB-SATA cable on a drive.
I was beginning to suspect the ProPioneer... nothing lasts forever and I wonder what I might replace it with, another ReadyNAS or other? If it were not for this forum, I'd be unsupported?
My other ReadyNAS is a RN316, and the used 16TB will go there.
Thanks, Ralph
- StephenBJan 24, 2022Guru - Experienced User
reburns wrote:I was beginning to suspect the ProPioneer... nothing lasts forever and I wonder what I might replace it with, another ReadyNAS or other?
That is a puzzle at the moment. ReadyNAS are in short suppply, and there are many who think Netgear is abandoning the market. (Netgear hasn't said).
If you are looking now, then you should definitely check out the competition, so you at least have a good idea on price/performance of current models.
