rklunder
Oct 18, 2014Aspirant
ReadyNas Pro Pioneer Resyncing issue
Hostname: NAS Model: ReadyNAS Pro Pioneer Edition [X-RAID2] Serial: 001f33ea2aeb Firmware: RAIDiator 4.2.27 Memory: 2048 MB [4-5-5-15 DDR2] IPv4 address: 1: 192.168.1.9 IPv4 address: 2: Not ...
rklunder
Oct 19, 2014Aspirant
Logs are sent. Reboot/resync issue still remains.
-resync finished,
-i installed the logitech media server add-on,
-ran a backup job which moves files from a USB drive to the ready nas
Problem: The system has restarted twice for no apparent reason. Also, what size should my NAS be with 6x2TB disks? It only shows Volume C: Online, X-RAID2, 6 disks, 19% of 7394 GB used.
UPDATE: My system just started re-syncing again.
Configuration: RAID Level X-RAID2, 6 disks
Status: Resync 9% complete, Time to finish 350 hr 47 min, Speed 1396 KB/sec.
I do have NTI shadow software running on various computers if that helps any.
-resync finished,
Device Description Status
Disk 1 WDC WD2003FYPS-27Y2B0 1863 GB , 44 C / 111 F , Write-cache ON OK
Disk 2 WDC WD2002FYPS-02W3B0 1863 GB , 44 C / 111 F , Write-cache ON OK
Disk 3 WDC WD20EFRX-68EUZN0 1863 GB , 40 C / 104 F , Write-cache ON OK
Disk 4 WDC WD20EFRX-68AX9N0 1863 GB , 41 C / 105 F , Write-cache ON OK
Disk 5 WDC WD20EFRX-68AX9N0 1863 GB , 41 C / 105 F , Write-cache ON OK
Disk 6 WDC WD20EFRX-68AX9N0 1863 GB , 41 C / 105 F , Write-cache ON OK
Fan SYS 922 RPM OK
Fan CPU 2280 RPM OK
Temp SYS 59 C / 138 F [Normal 0-65 C / 32-149 F] OK
Temp CPU 33.5 C / 92 F [Normal 0-60 C / 32-140 F] OK
UPS 1 APC Back-UPS NS 600, Battery charge: 100%, 32 minutes OK
Severity Date Message
Sun Oct 19 10:33:04 EDT 2014 System is up.
Sun Oct 19 09:32:12 EDT 2014 System is up.
Sun Oct 19 09:32:04 EDT 2014 A previous run of backup job is still running. Check if that backup job has stalled, or you may need to adjust the backup interval to account for the amount of data you are backing up. [Job 005]
Sun Oct 19 09:09:41 EDT 2014 The Logitech Media Server add-on has been successfully installed.
Sun Oct 19 09:03:14 EDT 2014 Backup started. [Job 005]
Sun Oct 19 05:00:31 EDT 2014 RAID sync finished on volume C.
