rklunder
Oct 18, 2014Aspirant
ReadyNas Pro Pioneer Resyncing issue
Hostname: NAS Model: ReadyNAS Pro Pioneer Edition [X-RAID2] Serial: 001f33ea2aeb Firmware: RAIDiator 4.2.27 Memory: 2048 MB [4-5-5-15 DDR2] IPv4 address: 1: 192.168.1.9 IPv4 address: 2: Not ...
Oct 19, 2014Guru - Experienced User
If you are running single redundancy, the volume size should be 9 TiB. If you are running dual redundancy, then your number is about right.
rklunder wrote: Also, what size should my NAS be with 6x2TB disks? It only shows Volume C: Online, X-RAID2, 6 disks, 19% of 7394 GB used.
I can't tell from the log snippets whether your RAID array is dual redundancy or not. The volume status page in frontview should tell you.
Are you seeing SMART errors?
