rklunder
Oct 18, 2014Aspirant
ReadyNas Pro Pioneer Resyncing issue
Hostname: NAS Model: ReadyNAS Pro Pioneer Edition [X-RAID2] Serial: 001f33ea2aeb Firmware: RAIDiator 4.2.27 Memory: 2048 MB [4-5-5-15 DDR2] IPv4 address: 1: 192.168.1.9 IPv4 address: 2: Not ...
rklunder
Oct 19, 2014Aspirant
Thanks for the reply, it is X-RAID2 mode (as shown in what you referenced which was from Frontview home page), I believe that is what you mean by dual redundancy. Or I do recall selecting the raid choice that allows 2 drives to fail. The drives look fine (see below).
BTW: my re-sync rate has increased considerably then what was shown above, I guess the backup job ended or crashed.
Configuration: RAID Level X-RAID2, 6 disks
Status: Resync 4% complete, Time to finish 5 hr 20 min, Speed 95.1 MB/sec
However it has rebooted 2 more times since what was posted above:
Severity Date Message
Sun Oct 19 15:42:32 EDT 2014 System is up.
Sun Oct 19 13:32:30 EDT 2014 System is up.
Sun Oct 19 10:33:04 EDT 2014 System is up.
Sun Oct 19 09:32:12 EDT 2014 System is up.
Sun Oct 19 09:32:04 EDT 2014 A previous run of backup job is still running. Check if that backup job has stalled, or you may need to adjust the backup interval to account for the amount of data you are backing up. [Job 005]
SMART Information for Disk 1
Model: WDC WD2003FYPS-27Y2B0
Serial: WD-WCAVY7332326
Firmware: 04.05G11
SMART Attribute
Raw Read Error Rate 1
Spin Up Time 7341
Start Stop Count 1764
Reallocated Sector Count 0
Seek Error Rate 0
Power On Hours 9272
Spin Retry Count 0
Calibration Retry Count 0
Power Cycle Count 1762
Power-Off Retract Count 1685
Load Cycle Count 78
Temperature Celsius 40
Reallocated Event Count 0
Current Pending Sector 0
Offline Uncorrectable 0
UDMA CRC Error Count 0
Multi Zone Error Rate 0
ATA Error Count 0
SMART Information for Disk 2
Model: WDC WD2002FYPS-02W3B0
Serial: WD-WCAVY5689612
Firmware: 04.01G01
SMART Attribute
Raw Read Error Rate 0
Spin Up Time 6800
Start Stop Count 2336
Seek Error Rate 0
Power On Hours 9760
Spin Retry Count 0
Power Cycle Count 1774
Power-Off Retract Count 1695
Load Cycle Count 1180
Temperature Celsius 41
ATA Error Count 0
SMART Information for Disk 3
Model: WDC WD20EFRX-68EUZN0
Serial: WD-WCC4M9PVV32E
Firmware: 80.00A80
SMART Attribute
Spin Up Time 4016
Start Stop Count 177
Seek Error Rate 0
Power On Hours 42
Spin Retry Count 0
Power-Off Retract Count 176
Load Cycle Count 59
Temperature Celsius 36
ATA Error Count 0
SMART Information for Disk 4
Model: WDC WD20EFRX-68AX9N0
Serial: WD-WCC1T1183888
Firmware: 80.00A80
SMART Attribute
Spin Up Time 5241
Start Stop Count 1754
Seek Error Rate 0
Power On Hours 9303
Spin Retry Count 0
Power Cycle Count 1754
Power-Off Retract Count 1681
Load Cycle Count 72
Temperature Celsius 37
ATA Error Count 0
SMART Information for Disk 5
Serial: WD-WCC1T1173773
Firmware: 80.00A80
SMART Attribute
Spin Up Time 5233
Seek Error Rate 0
Power On Hours 9306
Spin Retry Count 0
Load Cycle Count 72
Temperature Celsius 38
ATA Error Count 0
SMART Information for Disk 6
Serial: WD-WCC1T0804620
Firmware: 80.00A80
SMART Attribute
Spin Up Time 5675
Start Stop Count 1755
Seek Error Rate 0
Power On Hours 9311
Spin Retry Count 0
Power Cycle Count 1755
Power-Off Retract Count 1682
Load Cycle Count 72
ATA Error Count 0
