rklunder
Oct 18, 2014Aspirant
ReadyNas Pro Pioneer Resyncing issue
Hostname: NAS Model: ReadyNAS Pro Pioneer Edition [X-RAID2] Serial: 001f33ea2aeb Firmware: RAIDiator 4.2.27 Memory: 2048 MB [4-5-5-15 DDR2] IPv4 address: 1: 192.168.1.9 IPv4 address: 2: Not ...
Oct 19, 2014Guru - Experienced User
No. The original XRAID didn't allow mixed sizes of drives. XRAID2 added that.
rklunder wrote: Thanks for the reply, it is X-RAID2 mode (as shown in what you referenced which was from Frontview home page), I believe that is what you mean by dual redundancy.
Single/Dual redundancy is something different. You would have selected adding a drive for redundancy. The volume page should tell you if you have dual redundancy (e.g., RAID-6 XRAID2). Dual redundancy provides protection against 2 drive failures, so the volume size ends up 4x2TB in your case.
Agreed, there is nothing odd in the SMART stats.
rklunder wrote: The drives look fine (see below).
Which of course is not healthy. Hopefully mdgm will see something in the logs.
rklunder wrote: However it has rebooted 2 more times since what was posted above
