rklunder
Oct 18, 2014Aspirant
ReadyNas Pro Pioneer Resyncing issue
Hostname: NAS Model: ReadyNAS Pro Pioneer Edition [X-RAID2] Serial: 001f33ea2aeb Firmware: RAIDiator 4.2.27 Memory: 2048 MB [4-5-5-15 DDR2] IPv4 address: 1: 192.168.1.9 IPv4 address: 2: Not ...
rklunder
Oct 20, 2014Aspirant
That appears to be a typo. I think i did align the cut and pasted text which probably caused it. Below is an untouched cut and paste. BTW, all is working fine right now. I am running the extended test on the drive that was labeled as dead mentioned in the first post (which was replaced by disk 3 shown below). I would expect this drive to be the one to show issues since it was deemed dead by the readynas.
Disk space
1386 GB (18%) of 7394 GB used
RAID Configuration
Configuration: RAID Level X-RAID2, 6 disks
Status: Redundant
RAID Disks:
Ch 1 : WDC WD2003FYPS-27Y2B0 [1863 GB]
1858 GB allocated
Ch 2 : WDC WD2002FYPS-02W3B0 [1863 GB]
1858 GB allocated
Ch 3 : WDC WD20EFRX-68EUZN0 [1863 GB]
1858 GB allocated
Ch 4 : WDC WD20EFRX-68AX9N0 [1863 GB]
1858 GB allocated
Ch 5 : WDC WD20EFRX-68AX9N0 [1863 GB]
1858 GB allocated
Ch 6 : WDC WD20EFRX-68AX9N0 [1863 GB]
1858 GB allocated
