onyxmueller
Aug 25, 2012Aspirant
Readynas Pro Pioneer won't power up
Hello all, My Netgear ReadyNAS Pro Pioneer does not want to turn back on after a clean shutdown. Early today, I needed to physically move the device to another location. I pressed the front power b...
onyxmueller
Aug 27, 2012Aspirant
PapaBear wrote: This is rather basic, but assuming that there is another working device connected to the outlet, have you tried another modular power cord?
Just a point, x-86 based units (Original Pros, NVX, Ultras and new Pros), if they have been powered down normally, should power back up automatically once power has been removed from the device and power is reapplied. One thing that will interfere with that is if the unit suddenly loses power, it must be manually restarted. Also if there was an automatic shut down/power up schedule in place, on some older firmware versions if you manually shut down the unit, you will have problems restarting the unit.
I have tried a different power cord...no avail. Also, there was not a shut down/power up schedule in place to my knowledge. Up until the (physical) move, I rarely shut it down.
