onyxmueller
Aug 25, 2012Aspirant
Readynas Pro Pioneer won't power up
Hello all, My Netgear ReadyNAS Pro Pioneer does not want to turn back on after a clean shutdown. Early today, I needed to physically move the device to another location. I pressed the front power b...
mdgm-ntgr
Aug 27, 2012NETGEAR Employee Retired
Have you checked that the RAM is properly seated? It may have come loose when you moved the system, however you'd still expect some responsiveness if that were the problem.
