onyxmueller
Aug 25, 2012Aspirant
Readynas Pro Pioneer won't power up
Hello all, My Netgear ReadyNAS Pro Pioneer does not want to turn back on after a clean shutdown. Early today, I needed to physically move the device to another location. I pressed the front power b...
onyxmueller
Aug 28, 2012Aspirant
mdgm wrote: Have you checked that the RAM is properly seated? It may have come loose when you moved the system, however you'd still expect some responsiveness if that were the problem.
I did check the RAM when the issue first started. But yesterday, after your suggestion, I tried to re-seat the single stick in the other available memory slot. Still nothing.
Thank you for your suggestions. If you have anymore, please let me know. In the meantime, I have a case open with support. Would you happen to know if I can purchase an agreement or an extended warranty to get faulty hardware replaced (e.g., power supply) in the ReadyNAS if my default warranty expired a couple of months ago?
