onyxmueller
Aug 25, 2012Aspirant
Readynas Pro Pioneer won't power up
Hello all, My Netgear ReadyNAS Pro Pioneer does not want to turn back on after a clean shutdown. Early today, I needed to physically move the device to another location. I pressed the front power b...
Nov 04, 2013Guru - Experienced User
You are complaining even though your 4-year hardware is still covered by warranty? :?
ehgeahrev wrote: How has it been solved? Have a 4y old unit (mostly powered off) with the same problem. Not looking forward to a RMA procedure.
It doesn't look we get the product quality one should expect from Infrant/Netgear after all.
