onyxmueller
Aug 25, 2012Aspirant
Readynas Pro Pioneer won't power up
Hello all, My Netgear ReadyNAS Pro Pioneer does not want to turn back on after a clean shutdown. Early today, I needed to physically move the device to another location. I pressed the front power b...
jcastrojjc
Jun 30, 2015Aspirant
Labdoc, I have the same exact problem. I see the LAN port flickering weak amber light.
Can you advise which Power Supply and Extension cord you purchased? Is it the following PSU and Cable?
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151089
http://www.newegg.com/Product/Product.aspx?Item=N82E16812200121
