onyxmueller
Aug 25, 2012Aspirant
Readynas Pro Pioneer won't power up
Hello all, My Netgear ReadyNAS Pro Pioneer does not want to turn back on after a clean shutdown. Early today, I needed to physically move the device to another location. I pressed the front power b...
fastfwd
Dec 23, 2013Virtuoso
falco wrote: Is this a throwaway or can you purchase power supplies ??? :evil:
The power supply in my Pro Pioneer (and probably yours as well) is a Seasonic SS-300SFD. Replacements are available from numerous online vendors for $45-$60.
Hitman202
Oct 29, 2015Tutor
Is the Seasonic SS-300SFD the only psu that can be used with the Pro Pioneer?
I have a Pioneer that has recently died it appears.
It showed the constant reboot symptom that I have read about in other forums for a while.
Then at last didn´t turn on at all.
I have tried replacing the psu with a differet one.
It´s a working atx psu. It doesn´t fit in the cabinet (sits outside), but all the cables fit and are safely connected (power 24pin,4 pin, psu fan and 3xmolex)
Can this rule out the psu as being the problem or am i doing something wrong?
The only "life" it shows right now is the blinking lan lights:-(
