Ear-Relevant
May 22, 2017Aspirant
ReadyNAS Pro rebooting and resyncing, with file copy hangups and other issues
I have been using a ReadyNAS Pro RNDP6350-100NAS for many years as a home music server (Logitech Media Server) and backup for my PC and data files. Firmware is 4.2.30. It has not been 100% st...
Ear-Relevant
May 25, 2017Aspirant
Moderators? Anyone?
- StephenBMay 25, 2017Guru - Experienced User
The battery provides power to the real-time clock (RTC) when the NAS is not otherwise powered. That won't be causing your problems.
Can you post the SMART stats for the ST32000644NS?
Also, can you download the log zip file, and look in disk_usage.log? Please post the line that starts with /dev/md0
- Ear-RelevantMay 25, 2017Aspirant
StephenB,
Thanks for your response.
Here is the line from disk_usage.log -
/dev/md0 4.0G 1.9G 2.0G 49% /
S.M.A.R.T. for disk 1 -
Model: ST32000644NS
Serial:
Firmware: SN12
SMART Attribute
Spin Up Time 0
Start Stop Count 4918
Reallocated Sector Count 0
Power On Hours 17646
Spin Retry Count 0
Power Cycle Count 1734
End-to-End Error 0
Reported Uncorrect 0
Command Timeout 0
High Fly Writes 1
Airflow Temperature Cel 24
G-Sense Error Rate 0
Power-Off Retract Count 90
Load Cycle Count 4919
Temperature Celsius 24
Current Pending Sector 0
Offline Uncorrectable 0
UDMA CRC Error Count 0
ATA Error Count 0Looking forward to your interpretation.
Model: ST32000644NS
Command Timeout 0
ATA Error Count 0I asked about this because there was a log snippet above that indicated command timeouts with this disk model (though it thought the disk was in slot 6).
Perhaps look at the remaining disks, just to make sure there is nothing off.
This is high, but doesn't appear dangerously so. Do you have add-ons installed on the NAS? If so, which ones?
